hp dv6- 6121ee no power + charging led ok HELP
  • doctormasry
    • 108
    • giza
    Mb id : HPMH-41-AB6200-E00G
    NO POWER BUT WHEN I PUT ADOPTER THE LED IS OK WHAITE LED
    PRESS POWER = 3.3V PUT WHEN I PRESS NO POWER
    CHANGE BIOS EC AND MAIN BUT NO NEW
    PL806 = 3.3 # PL804 = 0V BUT AFTER PRESS POWER = 5V
    DB_PWRBTN# = 3.3 ON SW6 AND U19 AND CONNETED
    SB_PWRBTN# IS 0V AFTER PRESS POWER BECOME 3.3V
    RSMRST# ON U19 PIN 97 IS 3.3 V
    PL8011 = 1.1 V ---- PL812 0V AFTER PRESS POWER 1.5V
    ANY IDEA PLEASE HELP
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: hp dv6- 6121ee no power + charging led ok HELP
    first check +V3.3A_RTC RTC_RST# after check RSMRST# should go 3.3 to 0V when press PWBTN depends on the platform & LD05 LDO3 ?
    • doctormasry
      • 108
      • giza
      rtc =3.3 v
      rtc_rst = ok
      rsmrst is ok
      any another idea
      • doctormasry
        • 108
        • giza
        rsmrst on R121 is 0v after press pwbtn = 3.3
        rsmrst on u19 ITE pin 96 is 0v before press PWBTN . after press = 3.3v
        RTC_RST# on D806 = 3.3
        any another idea
        • Techtiger
          • Oct 2014
          • 1602
          • france
          now find out 15V_ALW / ADP_ID / EC_RST#
          RUN_ON / 3.3VSTBY_PCH_EN / SUS_ON /SLP_S4# SLP_S3# when press PWBTN ,
          • doctormasry
            • 108
            • giza
            thanks @techtiger i will check
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • Scoff
              HP Probook 470 G4 - Power and Charging Problem
              by Scoff
              Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
              Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
              07-03-2023, 09:28 AM
            • rob_hen
              Dell XPS 13 9370 Laptop, No power, not charging
              by rob_hen
              Hello!
              This is my first post for help, and I am quite newer to board repair, so bear with me.
              I have this board here (LA-E671P), with no power, and doesn't charge. No lights come on when plugged in.
              After visual inspection of the board, U22 is obviously blown up. This is the for backlight, and there is no shorts present after removing the chip and replacing.
              There is 3 USB C ports to power this board, USB 1 gives 20V, while 2 and 3 only give 5V.
              My observations using USB 1 at 20V (0.075A draw on Ammeter, slowly drops from 0.136A)...
              05-01-2025, 09:20 PM
              Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
              I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
              https://www.ebay.com/itm/116497313155?var=416785404161
              Here are some of the description from the eBay seller
              The main parameters:
              1. Product name: High-power non-isolated DC boost module power supply.
              2. Product model: 100A2000W.
              3. Input voltage: DC12V-60V.
              4. Input current: 100A (maximum)....
              05-18-2025, 09:45 AM
            • Dr.d
              Help please..Lenovo ideapad 5 14itl05 power and charging problem
              by Dr.d
              I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
              Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
              04-05-2024, 11:48 AM
