Dell XPS 9560 AC Adapter Unknown
  • iganas
    • Mar 2016
    • 14
    • Denmark
    Re: Dell XPS 9550, Unknown Charger
    Hi there, I am hunting down an exact issue, however locating PR102 seems to be a huge challenge. It seems to be nowhere close to PQ100 and does not have its own silk label on the board. I can see a trace going from PQ100 down into a via, which should lead to PR102, but that via continues in the inner layers of the PCB and good luck tracing that..
    • iganas
      • Mar 2016
      • 14
      • Denmark
      Managed to source a boardview file from this github thread and open it with Allegro viewer:
      https://github.com/OpenBoardView/Ope...iew/issues/194
      So it seems that my board is actually 9560 (silly mistake) and that this model has gotten rid of the PR102 resistor - it does not exist anymore. Which then leaves PQ100 as the only possible culprit. Correct?
      • iganas
        • Mar 2016
        • 14
        • Denmark
        Re: Dell XPS 9560 AC Adapter Unknown
        Originally posted by mgrharry
        Fixed. Thanks to @mcplslg123 for serving it up on a platter. I was misreading the schematic and had replaced two other resistors but once I located and replaced the 33ohm resistor off PQ100, problem solved.
        Hi there, I have the exact same board with exact same issue.
        Where is the location of that 33 ohm resistor? Or at least do you remember its component code? It is not PR102 as in the older 9550 board
        • mon2
          • Dec 2019
          • 14668
          You will have to post pics of your logic board. Guessing it will be near the adapter connector area.
          It will be an 0402 sized smd part. Should be black in body color.
          • iganas
            • Mar 2016
            • 14
            • Denmark
            Found the PR102 resistor on the 9560 board - it is on the same side as PQ100, right below HDMI port, unmarked, sitting between between LT13 and PL104. It was at 600 ohms instead of 33. Charger is now being recognized after replacing it
            • mon2
              • Dec 2019
              • 14668
              Thanks for the update. For future readers, can you post a pic with the location of this resistor ?
              • binoyroy
                • Sep 2017
                • 51
                • bangladeah
                #27
                Originally posted by mptcultist
                hi, i recently got an xps 9550 that won't charge due to the "unknown charger" psid issue.
                I replaced pq100 to no change, pr102 reads at 33 ohms, pr101 reads at 2.2k. When pq100 is removed, the source pad reads at 3.3v, the gate reads at 5v, and the drain at 0v. When it is in place, both drain and source read at 1.4v, and gate still reads at 5v. Pd100 is blown clean off and as such reads basically open.
                I don't know what exactly to do from here, except maybe investigate pq101.
                remove pd100 and check.
                • YOUCEF4787
                  • May 2014
                  • 22
                  • ALGERIA
                  #28
                  Which kbc it uses?? You need to find AD_ID pin on kbc and check whether you have stable and correct voltage there. Trace it back for a resistor valued 33.3Ohms which is culprit in many cases for adapter identification failure.
                  thans
                  • gs84
                    • Dec 2022
                    • 36
                    • Ukraine
                    #29
                    here!
                    • Andreasbest
                      • Aug 2014
                      • 1196
                      • Hellas ( Greece )
                      #30
                      My PR102 is 1ΚΩ, should i replace just this or the PD100 too?
                      • mon2
                        • Dec 2019
                        • 14668
                        Re: last post in this thread.
                        is your board the same? Does not appear to be. Note the connector to the left is not the power adapter connector.
                        post full details of your motherboard before replacing any parts.
                        • Andreasbest
                          • Aug 2014
                          • 1196
                          • Hellas ( Greece )
                          #32
                          I haven't upload any pictures of my motherboard, what you comparing?
                          Anyway, it's the same motherboard as gs84 and the resistor was indeed the cause of the trouble, i replaced it with a 33KΩ and everything i fine now
                          • mcplslg123
                            Dell 7506 2-in-1 laptop-no ac adapter issue
                            by mcplslg123
                            MODEL:ELL 7506 2-IN-1
                            M/B: HELLCAT 14 MS TGL 8L (19860-1)
                            PROBLEM: NO AC ADAPTER
                            The unit works fine with adapter but gives this message. The adapter is genuine dell 65W(tested ok). PS_ID is working correctly and reaches SIO.R4305 is correct at 33.3 ohms.
                            PU4301 gate is correct at 3.3V as well as PU4415 gate voltage at 1.8V is correct. 19V reaches PR4401(CLR).
                            Charging IC is ISL9538C
                            01 Resistance between CSIP/CSIN is about 2.2 ohms(PR4422/4423 is of correct value)
                            02.Resistance between CSOP/CSON is also correct at 2.4 ohms (PR4424-25 is...
                            11-18-2024, 11:34 PM
                            DELL XPS 9560 Notebook 15 Specification for Upgrade or Repair
                            This specification for the DELL XPS 9560 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9560 boardview and 9560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9560 Notebook...
                            09-06-2024, 07:11 AM
