Lenovo 320 no backlight
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Hello Folks
    Lenovo 320 -15AST
    Motherboard = NM-B321
    AMD with DDR 4
    Lenovo no backlight , Fan not turning on even the CPU get hot after a moment , not display at extern too.
    PSU =0.300 amp and increase !
    PL601/602 = 3/5 valaw ok
    Pl 2201 = +APU_CORE_NB = 0.897 v
    Pl 2202 = +APU_CORE = 0.897 v
    Bios Pin 8 = 1.8 V
    8/3 VS ok / 1.8VS ok / 0.95VS ok / 0.6 VS ok /
    PLT_RST = UL1 =Pin 19= 3.4v
    UE =
    pin 34 = EC_APU_ALWEN = 3.4V .
    Ram = +1.2V ok / +VDDSPD = 3.4V ok / +2.5V OK
    Flashed bios from web site /other site same issue , changing Screen same thing
    U7 = +3VS ok but no PCH_ENVDD.
    So , what i miss to check else !!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo 320 no backlight
    Check QC9 Working or not. Btw, is mb posting?? Usb KBD numlock glows??
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Thank you mcplslg
      No QC9 at this mobo ( @ ). not posting from HDMI too ,i try keyboard too nothing
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        So you confirm your mb is not posting. Why bother about the backlit issue? You are not supposed to get it unless the mb posts. So better check all rails.
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • techpointhull
          Lenovo V15 G3 No Backlight after liquid damage
          by techpointhull
          Good morning guys,
          I have a Lenovo V15 G3 that came in with liquid damage. The damage was very minor and some corrosion on the IO board where the power switch was. After cleaning both the motherboard and IO board in alcohol, the laptop turned on and I had backlight for about 3 seconds but nothing further. I don't have a boardview for this laptop (Have requested this in the Schematic Request section), however from previous experience on Lenovo laptops I have checked pins 1, 2, 3 on the EDP connector. When the battery is connected only, I get 8V and when AC adapter is connected, I get...
          11-28-2023, 01:57 AM
        • Echoo
          Lenovo ThinkBook 13s-IML (20RR) No backlight!
          by Echoo
          Hello!
          The image is visible, but there is no backlight! On older Lenovo laptops, this problem could have been solved by replacing a fuse, but now I can't find the solution!
          P207JXJ6...
          10-01-2025, 12:20 AM
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
        • XIII
          Lenovo CSA20 LA-D953P NO BACKLIGHT
          by XIII
          Hi, I have this Lenovo V510z AIO with the mobo CSA20 LA-D953P with no backlight at all, I've tried checking on different websites for schematics or anything leading to the location of the backlight circuit with no luck, there's nothing that seems to be burned out nor shorted is there any way to troubleshoot this issue? thank you in advance...
          06-18-2024, 12:38 PM
