Acer 5750 laptop. advice on which rail this fault is
  • bardos
    • May 2019
    • usa
    I took this motherboard out and it's on the bench now. Symptoms are I get fanspin and blue led light for a second or two and then it turns off, this repeats 4 times and then turns off completely. Any tips on which rail might be causing this?
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: Acer 5750 laptop. advice on which rail this fault is
    Many, but you can start by see if there's a short to ground .
    Make the basic tests : visually inspect all the components .
    what about 3/5 v always ! what about 3/5 vs !
    • rudelito
      • Jun 2019
      • 14
      • Phillipines
      mine to and i foundout the pch was extremly hot
      • mkdj
        Acer TravelMate P214 - N19Q7 main power rail shorted to ground
        by mkdj
        Dear all,
        I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
        I have checked resistance across each of the 4 MOSFETS. I have the following readings:
        Both N-Channel Mosfets: nothing odd
        P-Channel MOSFET number 1:
        source - drain : 117 kOhm
        source - gate: 96 Ohm
        gate - drain: 117 kOhm
        P-Channel MOSFET...
        08-20-2025, 06:08 AM
      • dariusgc
        Acer Nitro 5 AN515-55-53M3 (FH52M LA-J891P Rev: 1B) GPU memory rail
        by dariusgc
        Hello, i have Acer Nitro 5 AN515-55-53M3 (FH52M LA-J891P Rev: 1B), on GPU (nVidia RTX 2060) memory rail have ~0.5 Ohms resistance is it normal? or dead GPU?
        Prehistory: There was short on main rail, ~0,1 Ohms. Problem was double mosfet AOE6930 who is feeding GPU memory rail, i changed it and short is gone, and laptop turns on, but discrete gpu wont' work, video drivers install was succesfull. Some
        insights?​
        10-07-2025, 09:38 AM
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
        09-06-2024, 05:27 AM
        Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
        This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
        09-07-2024, 05:00 AM
