Dell D630 not turning on
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    Dell 630 dont turn on, when i plug the adapter the charging light will just flash and off, even when i fix the battery it dose the same thing, if i press the power button nothing no responds , sometimes when i plug adapter the power light will come on and when i feel the processor it get warm just for a while and shutdown , the fan will not spill, andno 5v to fan
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell D630 not turning on
    Check RTC section working or not
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      Dell Latitude D630 Laptop Schematic
      LA-3302P LA-3301P...
      10-08-2024, 12:19 PM
    • elzorroazul777
      [Troubleshooting] Dell T7610, computer won't post after turning on memory mapped IO >
      by elzorroazul777
      I have a Dell Precision T7610, 2 Xeon 2650 v2, 128Gb of ram, MB NK70N. Bought off of ebay in December and shipped with 1 processor and 64 gb of ram. I recently filled the other side of the board with processor #2 and 64 more Gb of ram. There are two gpu's, Nvidia K420 for video and Nvidia P40 for accelerated graphics. I have shelled out my entire budget on electronics tools and building this ‘homelab' computer. I do not have the money to buy another motherboard at this time, otherwise I would!
      The motherboard that shipped with the computer needed replacement as socket #2 wasn't...
      02-14-2023, 09:57 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
