820-4924-A Logic board Dead
  • mferna14
    • Jun 2018
    • 1046
    Hi, Working on a (Apple MacBook Pro A1502) 820-4924-A Logic board which is totally dead, no green light. The initial status was it was liquid spill & the green stuff collected on R7005 & Diode D7005. Both had corroded legs & the resistor was not even showing 10 Ohms. Replaced both of them but still no PPBUS_G3H (18.5V). First checked the DC-connector & the fuse, 18.5v present. I checked Q7010 & its fine but no output. Don't even get the PP18V5_DCIN_ISOL voltages. I checked Short to ground but none & no where liquid spill, all seems to be fine. Any help will be a great help. Thanks
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820-4924-A Logic board Dead
    Voltage on gate/drain/source of Q7010?
    • mferna14
      • Jun 2018
      • 1046
      Thanks, I figured out, the 6.8V Zener diode was corroded too. Now I get PPBUS_G3H (18.5V) where ever requried. The Magsafe green LED is on but no fan spin. I am missing the 5V rails. I get the 3.3v rails. Not getting P5VS3_EN signal on U7501, just getting .098V. which I think is not right. I check the resistors & all fine. Missing PP5V_S3_REG no voltage at all. If you can guide me through this too. Thanks
      • mferna14
        • Jun 2018
        • 1046
        & one more voltage is that PM_SLP_S4_L is .197 Volts where as this should be 3.3V
        • piernov
          • Jan 2016
          • 4439
          • France
          PPBUS_G3H should be 12.6V
          Confirm you are using a known good genuine Apple Magsafe2 60W/85W.
          Go down the list of power rails and report voltages… G3H, S5, SUS, S4… (can ignore S3 and S0 for now as we know they'll be missing if SLP_S4# is missing)
          Also area hit by the liquid damage will always give hints.
          • mferna14
            • Jun 2018
            • 1046
            I wansn't getting ALL_SYS_PWRGD.. So checked this FET Q8150, liquid spill on the pins. Replaced it & all works fine. Thanks a lot for all the help.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • yuuki47
              A2681 M2 MacBook Air Dead Logic Board
              by yuuki47
              Hello...
              My sister purchased an M2 MacBook Air a year and a half ago. While she was using it a week ago, it randomly shut off and no longer powers on. There are no signs of life and not even the MagSafe indicator LED lights up.
              We took it to Apple and they disconnected the battery and tried a bunch of stuff before they declared the logic board "brain dead" and quoted us about £567 to replace it. Typical of them...
              eBay replacements run about £367 with the Touch ID sensor included.
              I did consider to probe the logic board for shorts...
              04-13-2024, 06:22 AM
            • ohren
              Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
              by ohren
              I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
              I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
              The models launched in 2018 and 2019 respectively....
              09-08-2023, 05:24 PM
            • Yanleb
              LG 60PK550 Logic Control Board EBR63450301
              by Yanleb
              Hi all, I just want to share the repair of my 60PK550-UA TV set.
              The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
              But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
              All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
              C57: 3.30V
              C61:...
              07-20-2023, 12:38 AM
            • k370
              Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
              by k370
              I have a NM-A321 board that is dead, with no power at all.
              When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
              With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
              • +3VALW
              • +5VAUX
              • 1.2VSUS_PWRGD
              • 3VALW_PGD
              • 1.05VAUX_PWRGD
              Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
              The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
              09-23-2024, 11:57 AM
