Component with H Marking
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear Forum Members,
    I have a mainboard LA-6751P belonging to Lenovo G470.
    It contains a component called PH902 in the schematics:
    component name: PH902
    component specs: 10K_0402_5% ERTJ0ER103J
    What is this component? what are its properties?
    Is there any reference to study?
    It looks like a resistor but I do not know what are its differences compared to a resistor.
    • 21922
    Re: Component with H Marking
    Just do a google search for the part number. Its a thermistor https://industrial.panasonic.com/ww/...ls/ERTJ0ER103J
    https://www.ametherm.com/thermistor/...-a-thermistor/
    • diif
      • Feb 2014
      • 6978
      • England
      It's a thermistor.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        thank you
        Is it right to solder a 10-KOhm resistor instead of PH902 in the circuit of the picture?
        How can I measure specs of a thermistor from a donor board without schematics and boardview?
        • kodox
          • Jul 2017
          • 329
          • Indonesia
          i think, that thermistor is there for "heat-security" purposes. as i know, the value will change depend on surrounding temperature
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            what does happen to the +VGFX_Core voltage if I do not solder anything on PH902?
            what is your recommendation?
              • 21922
              Do a google search you`ll see the same part on quite a few compal boards.Search "10K_0402_5% ERTJ0ER103J" without the quotes "" . What donor boards do you have, search through your schematics for it.
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                I have got an idea:
                I solder a 10-KOhm resistor in place of PH902. Then, according to the datasheet of Post#3, it means the temperature is always low. Then, the controller thinks the temperature is fine.
                is this a good idea for this circuit?
                • harp
                  high voltage high resistance marking resistor
                  by harp
                  Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                  08-26-2024, 01:42 PM
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  Need help to replace burned resistor in 350w atx psu
                  by mikey5791
                  Hi to all forum members,
                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                  12-26-2024, 04:55 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
                • artvandalai
                  What resistor ohm will work better to repair this waterpik?
                  by artvandalai
                  The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                  01-05-2025, 04:10 PM
