Help me write a troubleshooting program for macbooks :)
  • krauterz
    • Oct 2019
    Hi guys.
    I have been poking around on this forum for some time now, mostly using it to help me identify issues with some of the Macbooks that come through our shop, and now that I have come to grips with the basics of logic board repair and diagnosis, I am hoping to write a little java applet that will help point me in the right direction quicker.
    I have the basics of the program nailed down, but am after some second opinions on some voltage questions.
    I understand I am new here, and that leeching answers off people is not exactly giving back to the community, but if it helps, I intend to make this applet open source/free to use once it is at a stage where it is not embarrassingly simple.
    If we assume that there is no signs of life on the board, aka, no fan spin, green/amber light etc, what would be a brief (100 words or less) "blanket" suggestion (aka, whats the most common cause in your experience) that you would give to someone who was experiencing either high voltages, or low voltages?
    PPBUS_G3H
    PPBUS_S5_HS
    PPBUS_S5_HS_OTHER_ISNS
    PPDCIN_G3H_ISOL
    PPDCIN_G3H
    PP3V42_G3H
    PPVRTC_G3H
    PP5V_S5
    PP5V_S4RS3
    PP5V_S0
    For example, someone on a different forum suggested "if PPBUS_G3H was low, this might suggest that you might have a short to ground, or a bad charging IC, where it is not producing more than 0.3V-0.5V.
    Check for a short on that line first, and also feel the charging chip to see if it gets hot. If there is a short, or the chip is getting hot, remove the chip first to see if there is no longer a short.
    If there is no short. replace the charging chip."
    Later down the track I hope to have more detailed answers depending on different voltage ranges (dead short, a volt too low, half what it should be etc etc) and other issues. this will include checkboxes on whether the user has any lights, fanspin, etc, offering suggestions for each.
    The application is in very beta stages at the moment, but I am happy to give examples on how I expect it to function.
    Any and all suggestions are welcome, even suggestions to go somewhere else. I understand what I am asking for here, and as I said before, any and all help is greatly appreciated.
    thanks
    - Edit
    I would also like to add that we are mostly focusing on the series of Macbook Air's and Pro's from between 2012 and 2015ish.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Help me write a troubleshooting program for macbooks
    Asking for some specific information is not a problem. But basically asking "tell me everything" is not very reasonable nor feasible. Personnally I like to share information but it takes a huge amount of time to write, it's difficult to organize and I wouldn't even know where to start, there's too much.
    There is a bunch of information that have been filled over here already:
    http://logiwiki.shinycomputers.com/index.php/Main_Page
    Feel free to contribute and organize it.
    • ahmedtou
      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
      by ahmedtou
      help me please
      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
      I will share all the details with you, including the disc information.
      Code:
      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
      Current Profile: BD-R
      Disc Information:
      Status: Empty
      State of Last Session: Empty
      Erasable: No
      Free Sectors: 12,219,392
      Free Space: 25,025,314,816 bytes
      Free Time: 2715:27:17 (MM:SS:FF)
      Next
      08-27-2025, 08:49 AM
    • DynaxSC
      Extreme High Current & Low Voltage Short Killer ??
      by DynaxSC
      Hi Folks
      I'm looking for a extreme high current short killer solution for a reasonable cost.
      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
      After taking off the socket, the shorts dissappear again.
      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
      10-15-2024, 10:13 AM
    • Stephen
      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
      by Stephen
      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
      02-06-2025, 12:03 PM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
    • pengamat_hebat
      Microsoft Surface Pro 5 1796 Short in Super IO/SAM M22J9VDC
      by pengamat_hebat
      Hi, I am repairing a Microsoft Surface Pro 5. I did some troubleshooting and found that resistor PR5575 feels hot. This resistor bridges +3P3VAS_REG to +3P3VAS.
      I then searched for the component that draws all the current from +3P3VAS and found the problem lies with the SAM/Super IO component U3600 (M22J9VDC/Kinetis K22F MK22FN512VDC12). By removing PR3605, I can confirm that this component is drawing all the current through pin L10 (Vdd).
      Can this component (M22J9VDC/MK22FN512VDC12) be replaced? I googled all day...
      05-27-2024, 07:08 AM
