Lenovo Y50-70 not working on power adapter, only on battery
  • costivl
    costivl
    • Apr 2020
    • 26
    • ROMANIA
    This laptop is not powering up with power adapter connected, it only works when battery connected, also it does not recharge battery, i did some checks and i have the following with battery disconnected:
    P2 - 20V
    VIN - 20,5V
    P3 - 0,6V
    i replaced PQ302 and i get the same voltages so PQ302 is not the fault in here.
    if i connect the battery i get 7V on P3 but battery not recharging.
  • emestee
    • Dec 2019
    • 228
    • Bulgaria
    Re: Lenovo Y50-70 not working on power adapter, only on battery
    Can be any number of things but you would start looking at and around the charger IC. Find schematics and boardview if you can.
    • costivl
      costivl
      • Apr 2020
      • 26
      • ROMANIA
      emestee thanks for answering, what should be the normal voltage on P3 ?
      • emestee
        • Dec 2019
        • 228
        • Bulgaria
        I don't know what "P3" is in your case, I don't know what board is in that machine and you haven't provided the schematics for it.
        • costivl
          costivl
          • Apr 2020
          • 26
          • ROMANIA
          Board schematics:
          https://www.laboneinside.com/lenovo-...matic-diagram/
          Check page 47 for PQ301 and PQ302
          I also checked PQ301 and PQ302 gate pins and i have 20V on both, it shouldnt be 5v or so?
          Let me know thanks!
          • lapfix
            • Mar 2020
            • 2724
            • my workshop
            The gate of Pq 301/Pq302 are generated by a voltage divider , you must find 8.5v .
            what's the voltage at PR311 from the 2 sides .
            PU301 voltage on pins : 20/5/6/16.
            • costivl
              costivl
              • Apr 2020
              • 26
              • ROMANIA
              I forgot to mention i have PR302 removed from board to protect B+ line
              Can you please help me locate PR311 on board, let me know if it is this one on the image thanks!
              • costivl
                costivl
                • Apr 2020
                • 26
                • ROMANIA
                I just found out that on PQ312, S and D was on short, that is why i had 20V on pin 4 of both PQ301 and PQ302, replaced the mosfet and now laptop works like a charm, thanks for help anyway!
                • ferah831208
                  Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                  by ferah831208
                  Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                  03-18-2025, 01:18 AM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • Grafnus
                  Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
                  by Grafnus
                  Hey there,
                  first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
                  So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
                  Specs:
                  • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
                  • CPU, GPU, RAM work fine (not involved in the Problem)
                  So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
                  Now I noticed...
                  Yesterday, 11:54 AM
                • code share
                  Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                  by code share
                  I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                  Here's what I've tried so far:
                  • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                  • Booted successfully on AC power only with the battery disconnected
                  • Visual inspection of the battery — no swelling, burn marks, or connector damage
                  • Battery
                  04-21-2025, 12:50 PM
                • mrkmpn
                  Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                  by mrkmpn
                  Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                  This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                  03-13-2024, 01:54 PM
