Lenovo Y50-70 not working on power adapter, only on battery
  • costivl
    costivl
    • Apr 2020
    • 26
    • ROMANIA
    This laptop is not powering up with power adapter connected, it only works when battery connected, also it does not recharge battery, i did some checks and i have the following with battery disconnected:
    P2 - 20V
    VIN - 20,5V
    P3 - 0,6V
    i replaced PQ302 and i get the same voltages so PQ302 is not the fault in here.
    if i connect the battery i get 7V on P3 but battery not recharging.
  • emestee
    • 228
    Re: Lenovo Y50-70 not working on power adapter, only on battery
    Can be any number of things but you would start looking at and around the charger IC. Find schematics and boardview if you can.
    • costivl
      costivl
      • Apr 2020
      • 26
      • ROMANIA
      emestee thanks for answering, what should be the normal voltage on P3 ?
      • emestee
        • 228
        I don't know what "P3" is in your case, I don't know what board is in that machine and you haven't provided the schematics for it.
        • costivl
          costivl
          • Apr 2020
          • 26
          • ROMANIA
          Board schematics:
          https://www.laboneinside.com/lenovo-...matic-diagram/
          Check page 47 for PQ301 and PQ302
          I also checked PQ301 and PQ302 gate pins and i have 20V on both, it shouldnt be 5v or so?
          Let me know thanks!
          • lapfix
            • Mar 2020
            • 2764
            • my workshop
            The gate of Pq 301/Pq302 are generated by a voltage divider , you must find 8.5v .
            what's the voltage at PR311 from the 2 sides .
            PU301 voltage on pins : 20/5/6/16.
            • costivl
              costivl
              • Apr 2020
              • 26
              • ROMANIA
              I forgot to mention i have PR302 removed from board to protect B+ line
              Can you please help me locate PR311 on board, let me know if it is this one on the image thanks!
              • costivl
                costivl
                • Apr 2020
                • 26
                • ROMANIA
                I just found out that on PQ312, S and D was on short, that is why i had 20V on pin 4 of both PQ301 and PQ302, replaced the mosfet and now laptop works like a charm, thanks for help anyway!
                • ferah831208
                  by ferah831208
                  03-18-2025, 01:18 AM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • code share
                  Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                  by code share
                  I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                  Here's what I've tried so far:
                  • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                  • Booted successfully on AC power only with the battery disconnected
                  • Visual inspection of the battery — no swelling, burn marks, or connector damage
                  • Battery
                  04-21-2025, 12:50 PM
                • mrkmpn
                  Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                  by mrkmpn
                  Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                  This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                  03-13-2024, 01:54 PM
                • pabloroggeri
                  Lenovo V310-15ISK - It doesn't work after changing the battery
                  by pabloroggeri
                  Good guys. I changed the battery to a Lenovo V310-15ISK.
                  The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
                  When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
                  08-23-2024, 12:01 PM
