Macbook pro problem DC or Baterry ?
  • zvonko72
    • Jul 2016
    • 20
    • Serbia
    Hello
    I have a problem with Macbook pro a1260 motherboard 820-2249
    Laptop can only fire when the battery is plugged in, then it can run without the battery only on the dc adapter
    Do you know what the problem is, i guess its something about battery charging?
    The laptop charges the battery!
    I tried reset smc...
    I have a scheme and boardview
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Macbook pro problem DC or Baterry ?
    Known good genuine Apple 85W Magsafe?
    Macbooks aren't designed to run without battery anyway.
    • zvonko72
      • Jul 2016
      • 20
      • Serbia
      Yes, i have the original Magsafe 85w
      I think it should work even without a battery
      • zvonko72
        • Jul 2016
        • 20
        • Serbia
        There is some idea where i can check ?
        • mferna14
          MacBook Air A2681 battery problem after Screen Replacement
          by mferna14
          Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
          12-06-2024, 08:10 PM
        • brockauly
          Macbook M1 A2337 EMC 3598 weird battery charging problem
          by brockauly
          Hi guys,
          If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
          Then if I unplug the charger and plug it back, it won't charge anymore.
          In the first case, main voltage is regulated at ~12.5V and charges the battery.
          After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
          After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
          I found C520A (2.2µ after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
          02-05-2025, 10:51 AM
        • sdogs
          Macbook Air 2020 A2179 820-01958 battery problem?
          by sdogs
          I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port intermittently).
          After a first inspection I could see that the D3302 protection IC was burnt out, so I replaced it but the problem was not solved, it seems like intermittent 5v input.
          I then replaced the two u3200s (CD3217B12ACE) and now I have stable 20 volts and the macbook has turned back on.
          Unfortunately I have a further problem, it works very slowly and the fan runs at maximum and if I disconnect the charger it turns off, it's as if the battery was disconnected.
          02-08-2024, 08:00 AM
        • ahmarzo
          Acer TMX314-51 laptop battery problem
          by ahmarzo
          I have acer laptop tmx314-51 with part no 6050A3020501.
          The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
          But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
          I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
          The schematic is not available...
          04-11-2025, 09:14 AM
        • gboone
          820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
          by gboone
          Hi, I was given this laptop by my uncle who said:
          • It would occasionally shutdown if not plugged in
          • battery had been replaced
          • touchbar would "strobe"
          I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
          After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
          BUT
          When powered off, it would at some point have a...
          01-27-2025, 09:12 AM
