820-00165A power button not working + RTC problem
  • MacbookAir
    • Apr 2020
    • Netherlands
    I have here a Macbook Air with the 820-00165A board inside. There was some liquid spilled on it and it has been to a repair shop that said they cleaned it and that didn't fix the problem.
    I am looking at it now and there are 2 issues with it. After the spill, the original user was unable boot OSX, it would hang during boot. Also there was an issue with the date, it was showing a date/time in the past. After the cleaning by the repair shop, the system no longer powers up using the power button.
    However, it does still start when the adapter is attached.
    I now installed Linux on an external HDD (USB) and with Linux it boots and runs fine, except that the date is set back to Jan 1, 2019 after each boot. Even after a warm restart (init 6).
    I took the board out and did some measurements with just the battery connected. The board does not start with the power button, also not when shorting the R5115/R5116 pads (without the keyboard attached).
    SMC_ONOFF_L 3,40V ok
    SMC_LID 3,40V ok
    SMC_ADAPTER_EN 0V ok
    SMC_RESET_L 3,37V ok
    SMC_LSOC_RST_L 3,39V ok
    PPVRTC_G3H 3,40V ok
    PM_BATLOW_L 0V (ok, because no PP3V3_S5?
    PM_PWRBTN_L 0V (ok, because no PP3V3_S5?
    I also check the PCH_CLK32K_RTCX1 signal with a multimeter, it looks like there is a clock signal.
    The board looks clean, there is no obvious corrosion visible anywhere.
    Does anyone have any suggestion what else I could look at?
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: 820-00165A power button not working + RTC problem
    You have to take the measurements with AC adapter connected and battery disconnected.
    Voltage on PPBUS_G3H, PPVRTC_G3H, PM_PWRBTN_L, RTC_RESET_L, PCH_SRTCRST_L especially.
    • MacbookAir
      • Apr 2020
      • Netherlands
      Thanks for your help.
      When I attach the adapter the board will power-on, so I measured the signals with the board running. They seem to be ok:
      PPBUS_G3H 8,58V
      PPVRTC_G3H 3,33V
      PM_PWRBTN_L 3,40V
      RTC_RESET_L 3,32V
      PCH_SRTCRST_L 3,32V
      • MobileXT
        • Oct 2012
        • 202
        Did you try another known working keyboard?
        • themosttogain
          HP Envy 13-BA1565na with intermittent power button
          by themosttogain
          Hope someone can give me some suggestions on this because i'm at my wits end with it...
          I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
          Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
          07-12-2024, 03:03 AM
          Acer TravelMate TMP215-53-340V Notebook P2 Specification for Upgrade or Repair
          This specification for the Acer TravelMate TMP215-53-340V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TMP215-53-340V boardview and TMP215-53-340V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
          09-07-2024, 05:00 AM
        • TimeRabbit07
          Asus FX517ZC charges but power button does nothing
          by TimeRabbit07
          Hi all!
          I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
          Here are its various numbers and identifiers:
          Model short: FX517Z
          Model long: FX517ZC-HN114W
          SN: NANRCX01S57842E
          CN: 3SDB 12M
          MFD: 2022-10
          Motherboard model: DA0NJLMBAE0 REV E
          Symptoms:
          The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
          History so far:
          The...
          09-04-2024, 05:48 PM
        • reessi
          Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
          by reessi
          With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
          No corrosion any where!
          Tried a replacement power button off ebay and the same.
          Very occasionally it will work with the power button connected!
          Same results with or without the battery.
          Can it be a fault with the Audio board or the mainboard?
          The touch Id assembly connects through the Audio board first then to the Mainboard.
          Flex...
          06-26-2024, 03:31 PM
        • x_orange90_x
          Seven Leagues Slot Machine stop button issues
          by x_orange90_x
          I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
          The issue now is the Stop buttons are intermittently...
          02-12-2025, 10:01 AM
