Acer 8943g shorted motherboard with LVDS connector
  • Roli
    • Jun 2010
    • 42
    Hello , so i forgot that my laptop had a battery in it ... and plugged in the lvds connector to the display, yes i know stupid , and then i smelled something burning , so when i started up the laptop i had a white screen , and after that not even a white screen anymore , it is black , no backlight and also no image , the vga port works fine , the laptop boots .
    I tried with a flashlight to see if there is image ,but no image.
    There was a small smd on the motherboard marked as : L43 , it was burned i changed it , but i still dont have any image , only on vga.
    And no the motherboard has no fuses near the Lvds, so maybe someone has a better ideea ?
    I have some images of the board and what i changed .
    Thankyou !
  • Roli
    • Jun 2010
    • 42
    Re: Acer 8943g shorted motherboard with LVDS connector
    Nobody any ideea ?
    • lapfix
      • Mar 2020
      • 2742
      • my workshop
      Make sure that your problem is NOT on LVDS cable or LED panel.change them and see if your issue is gone
      • Roli
        • Jun 2010
        • 42
        Thanks for replying , ive checked the lvds , its okay, but i managed to find an acer 15.6 inch display with same 40 pin connector and gues what , the display turned on perfectly , so now i know the motherboard is okay , lvds ok , all compoennts okay ,except the display
        The display board failed on the display , but again i dont see anything burnd or suspicious , so i think there is a short somewhere and cuts off the whole display , so it wont turn on , i see some test points on the displays board :
        LED_PWM
        LED_EN
        EE_VDD
        SC
        SD
        GND1
        N-WE
        Maybe someone repaird laptop display boards and can lead me further ?
        • Roli
          • Jun 2010
          • 42
          Ok so after a better examination i have found the problem ( posible problem ) , found a burned resistor , but the problem is i cannot see the value of it , i cannot read the middle of what it says on the resistor , only the left and right side but not the middle , ive made a picture .
          It writes E E , left and right side , but cannot determin on middle , now what should i do ?
          • khaahk
            • Dec 2013
            • 785
            • Estonia
            Look where the resistor is connected to. Zoomed out picture might be helpful. The planes that the resistor is connected to seem big, also there is a conductive tape on one of the planes, usually these are put on GND planes.
            Might be 3R3 resistor acting as current limiter.
            Not sure - so do not act on this suggestion.
            • lapfix
              • Mar 2020
              • 2742
              • my workshop
              Perfect , you can easy guess the resistor value , any 15.6 inch display / 40 pin connector can give you an idea .
              • Roli
                • Jun 2010
                • 42
                Ok i managed to change the resistor , the display still wont start , ive managed check an IC marked as : S24C02 , its a 2Wire serial eeprom , donno why but its verry hot , and its shorted to ground ...
                I think i am going to remove that and check if it works maybe without , but i dont think so ...
                  • 21209
                  The S24C02 is the EDID eeprom. You`ll need to program a new chip. What part number is the panel ,post a picture.
                  • Roli
                    • Jun 2010
                    • 42
                    The model number is N184H6 - L02 Rev.C1 , posted picture .
                    So basically i need to order a new chip and reprogram - it ?
                    If yes i have only 1 programmer , TL866 , need to check if it supports this chip ...
                    Or are there any other ways to program this ? Maybe using paralel port or serial port ?
                    And where can i get firmware for this ?
                      • 21209
                      I posted the bin in the LCD EDID dump thread, post #42 . https://www.badcaps.net/forum/showthread.php?p=957055
                      If you don`t have an adapter for the tl866 you could use an old lvds cable to flash it (post #6). Any 24C02 chip will do from an old panel, RAM ,HDD,scrap pcb .
                      • Roli
                        • Jun 2010
                        • 42
                        Wow thanks for the quick reply , i will try to find a good chip , hopefully today !
                        • Roli
                          • Jun 2010
                          • 42
                          Ok so i managed to program the new ic with the file you provided, the display turns on but its only white .
                          • Roli
                            • Jun 2010
                            • 42
                            Ok what i found just now that there is another ic that is getting verry verry hot , the writing on the ic is : CW=BJ 12R , i cannot find anything about this ic , what is this and where can i get one ?
                            Posted picture of the ic .
                              • 21209
                              Its a Richtek RT9921CGQV .https://cdn.badcaps-static.com/pdfs/...a0e8cd0c26.pdf
                              • Roli
                                • Jun 2010
                                • 42
                                I found a similar chip , posted picture , is that the same thing is it okay to change it ?
                                • Roli
                                  • Jun 2010
                                  • 42
                                  Nevermind that is an LED driver i think ...
                                  • Roli
                                    • Jun 2010
                                    • 42
                                    I will have to order it from china , it will take like 2 months because i dont have one , on this N184H6 display , there is another ic , it is not hot or anything , but im afraid if i order the RT9921 and change it , maybe this other ic will be hot to and i want to order that also because i dont want surprises , so on the other ic it writes DW=BK W16 , what ic is this ?
                                    Attached a picture
                                      • 21209
                                      It could be a Richtek RT8562BGQW DW=xx
                                      https://www.ebay.com/itm/3pcs-RT8562...-/401680959547
                                      EDIT: Datasheet https://cdn.badcaps-static.com/pdfs/...f12a8d7aee.pdf
                                      • Roli
                                        • Jun 2010
                                        • 42
                                        You have been verry helpfull , thankyou ! , and about that 2 ic-s that i need , are those available only in display's or can you find them maybe on laptop motherboards or something ?
