Dell E7240 Laptop
  • Spitz
    • Oct 2010
    • 95
    Dell E7240 Laptop
    Picked this up on Ebay, and it is in very good condition. When powered on, the power light lights and stays on, fan turns on after awhile, but nothing on screen and no other lights flash or turn on. When pressing the power button again it turns off. Battery charge light turns on and battery charges just fine. Battery holds charge. I plugged in a diagnostic card in the msata slot and post codes increment to 6A and stop there. Cannot find any information on post codes for this model. Dell was no help, all they wanted was for me to send it in for service. I can find replacement motherboards on ebay, but would rather fix this one if I could. Do not see any damage of any kind to the board. Hooked it up to a monitor just to make sure it was not the display and got the same symptoms. No beeps either. I did find a schematic for this model. Anybody run into something like this or got any ideas on what might be the problem?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Dell E7240 Laptop
    Known good compatible RAM?
    Tried BIOS recovery procedure?
    • Spitz
      • Oct 2010
      • 95
      Yes, I tried a different ram modules.
      Not sure this model supports bios recovery, but tried the F2 button with no results. I did notice that when pressing power button to turn off the hdd light flashes.
      • piernov
        • Jan 2016
        • 4439
        • France
        https://www.dell.com/support/article...tablet?lang=en
        • Spitz
          • Oct 2010
          • 95
          Again not sure this laptop supports bios recovery, but tried the ctrl-esc sequence, stll nothing on screen.
          • Spitz
            • Oct 2010
            • 95
            Pretty sure its a bios problem. I have ordered a ch341a programmer and will try to reload the bios when it comes in.
            • pepegotera454
              • Jul 2014
              • 15
              • andorra
              Check with the oscilloscope if pin 1 has data transfer, so you can know if the bios is corrupted.
              • Spitz
                • Oct 2010
                • 95
                I don't have an oscilloscope, but I think there is data or the diagnostic card would not have incremented up to code 6A. The problem is it stops before it can finish the bios to move on to booting the system.
                • Spitz
                  • Oct 2010
                  • 95
                  Just to give an update, it was a bios problem. Received the CH341A programmer with test clip and it worked perfect. Did not have to un-solder, just put the clip on and was able to erase and program both bios chips.
                  • manol278
                    Dell laptop E6440 val91 la-9934p turns off
                    by manol278
                    Hi. I have problem with dell laptop E6440 val91 la-9934p rev.1.
                    I turn on the laptop and it turns off instantly. After 5-6 attempts it turns on normally. I saw that it was burnt PU800, CD3301B Power Controller Chip.
                    If you see in the photo someone tried to do bypass and remove PR831, PR832, PC820, PR838.
                    I will replace CD3301B. I have the schematic but i dont know what are the characteristics of other componets to replace...
                    [Mod. Edit]
                    Schematic -> https://www.badcaps.net/forum/troubl...cs-theory/trou...
                    01-26-2024, 11:50 AM
                  • keepread
                    Dell monitor PSU vs Dell laptop PSU
                    by keepread
                    Hi there!
                    Someone gave me their old monitor, it's Dell S2715ht.
                    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                    Yesterday, 04:45 PM
                  • andrhouseolly
                    Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                    by andrhouseolly
                    Hi.
                    I kindly ask you to help me solve the problem.
                    Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                    The board turns on, there is no image.
                    Read more. When the power supply is connected, the front panel indicators light up briefly.
                    When you press the power button, the button indicator lights up. The board works
                    there is no image, there is no matrix initialization, there is no image on HDMI.
                    When turned on, the fans do not spin, but when they warm up they start spinning.
                    When you turn off the button, the fans spin up to full speed for a short...
                    05-11-2024, 03:14 PM
                  • mikey5791
                    Dell laptop model PP24L won't start from ac adapter
                    by mikey5791
                    Dear all,
                    Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
                    But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
                    03-24-2023, 09:06 PM
                  • Mots06
                    Old Dell E5400 Laptop ( Purchased in the year 2008)
                    by Mots06
                    Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
                    07-19-2025, 01:56 AM
