Lenovo B51-80 No POST after shorted High side mosfet on CPU
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3641
    • slovakia
    Hello.
    Have this Lenovo B51 that have shorted High side mosfet on CPU line. After repair i have all voltages, fan and led works, i have backlight, but have NO POST
    do u thing that this cpu is burned?
    try to flash bios but no luck
  • Dumah Brazorf
    • Jun 2013
    • 179
    • Italy
    Re: Lenovo B51-80 No POST after shorted High side mosfet on CPU
    Shorted high side means it has sent plain 19V (or battery voltage) to the cpu. Too much for an overclock...
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3641
      • slovakia
      it never reach 19V. there is lowside mosfet that shorts it to ground driven by poweric, but looks like it dont do it so fast so average voltage behind coil and capacitors goes over max voltage of CPU
      • kiraro
        • Jan 2016
        • 177
        • North NY
        I think the resistance of "Cpu_Vcore" section it's very low, so when the upper side is defected the charger circuit section will block "19v" because it's like a short to ground (exceeded current) for him and never you will find "B+" active in this case.
        In my opinion try to change lower side (it's recommended to change both when one of them defected) and the Vrm circuit , and trace power good and reset signals for Cpu .
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3641
          • slovakia
          i changed them both
          found that even power switching circuit is damaged because not work and work only sometimes.
          Cannot trace VRM and reset signals because dont have schematic
          • kiraro
            • Jan 2016
            • 177
            • North NY
            what is the full model number of the motherboard?
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3641
              • slovakia
              BIWB6/B7/E7/E8
              LA-D102P rev.1.0
              • Nooy
                VGA MOSfet permanently shorted and loss of MOSfet pad
                by Nooy
                Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                02-14-2024, 02:26 AM
              • zwerw3
                High side mosfet of the power supply of the RTX2060 graphic chip burned out
                by zwerw3
                Hello. They brought a personal computer for repair in which the video card was GeForce RTX ™ 2060 WINDFORCE OC 6G (rev. 1.0). Graphics core power mosfet burned out.
                Is there a chance to restore the site where the mosfet was? I started to grind the mosfet substrate with a dremel, which stuck to the board, but for now I stopped and decided to ask you for advice. I also noticed dark spots on the PCB near the video memory chips. Does this mean that the video memory is out of order? I cleaned the place where there was a burnout, a short circuit of 12 V was removed. On the coils on the power...
                12-12-2022, 12:15 AM
              • dougg3
                Intel DX58SO high side VRM MOSFET keeps failing
                by dougg3
                Hi there,
                I have an Intel DX58SO motherboard that failed last year. One of the high side VRM MOSFETs failed shorted, and it killed my i7 980 CPU. This motherboard has a 6-phase VRM. The parts used on this motherboard's VRM are:
                • 6 x High side MOSFET: NTMFS4841NH
                • 6 x Low side MOSFET: NTMFS4834N
                • 6 x Driver: ADP3121JCPZ
                It was easy to figure out where the short was, because the bad MOSFET's gate was shorted to the drain/source too. Once I removed it, all the shorts were gone on the motherboard, and I confirmed on the removed MOSFET itself that the gate/drain/source...
                10-17-2021, 07:39 PM
              • pavithra_uk
                Optiplex 3050 Vcore Mosfet short
                by pavithra_uk
                it is 3+2 vrm
                vcore high side mosfet (AON6380) shorted when turned on instatly killed the processor (i5 7400)
                gate drive chip (NCP81166) also gone.
                any suggestions before replace mosfet and gate drive chip? what if I replace 3 high side mosfets with more current capable mosfets?
                odd question:
                what if I put two silicone diodes series in forward way? assume each diode 0.7v drop and total of 1.4V. vcore not exceed this but can protect cpu from direct 12V hit from shorted mosfet ?...
                10-21-2025, 11:32 AM
              • chestercc
                Alienware M18x Shorted CPU Mosfet
                by chestercc
                I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
                I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
                Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
                07-16-2022, 06:05 AM
