guys i cannot even count how many of this asus x555ld have in hand and noone have working touchpad. what is wrong with these laptops? have anybody solution for this?
					Asus x555LD touchpad not working
	Tags: None
Re: Asus x555LD touchpad not working
sorry guys for bothering u . do update drivers and this is first one of MANY that works :-)
but if u have 100% solution please share it because i have MANY of it with not working touchpad -
About drivers: if it's Windows 10, try to manually install Synaptics 18.x.xx drivers and double check touchpad is not disabled. A lot of laptops more than a few years old won't work properly with Synaptics 19.x.xx and that's what Windows 10 installs by default.
Also try a Linux LiveUSB to exclude a software problem.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
On these models if you test the motherboard without the touchpad when you reconnect it , it's possible that the OS don't recognize the device. After one or two restart the situation return normally. In other stuation the fat cable is the culpritt.Last edited by jasko_jacker; 03-14-2020, 11:27 AM.Comment
			by rheyntauCAN ANY ONE HELP ME WITH THIS PROBLEM....ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10 ..IT WAS ELAN TOUCHPAD..I DOWNLOAD A DRIVER BUT ITS NOT WORKING IT SAYS "WINDOWS FOUND DRIVERS FOR YOUR DEVICE BUT ENCOUNTERED ERROR.....THE HASH FOR THE FILE ISNOT PRESENT INTHE SPECIFIED CATALOG......."
			by kacangpoloHello, I have a problem with my laptop,
Before my laptop had no display, then I tried to flash and restore my Serial Number from old BIOS; my laptop can display, but the touchpad doesn't work,
I tried to update bios from Ez Flash but still it doesn't work,
this my old BIOS
SN : M9N0CV16W71138A...-
							Channel: BIOS Requests ONLY!
			by Yosuahi friends, I hope someone can help me with this asus x450ep rev 2.0 mobo case, the problem is the touchpad doesn't work, I've tried with another asus touchpad, but still, I've never got this touchpad case, I'm confused where to measure from...
			by MichelinManHey guys,
Just purchased a CF-20 (mk1) supposedly was all working. However, the seller had done a fresh install of windows 10 but did not install any driver. Seller was adamant the trackpad/touchpad was working.
The touchpad/trackpad does not work. No led lights near the trackpad. The keyboard works, the USB 2 port on the base does not work, The USB 3 ports will recognise a USB 3 flashdrive but did not recognise a USB mouse. The ethernet port on the keyboard section works.
The USB 3 port on the actual tablet section works with no issues.
			by DynaxSCHi,
I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
The behaviour is also really very strange, i.e.:- The disk shows always up in BIOS - so it is recognized, so far so good
 - POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
 - Loading...
