I need help on this LENOVO IDEAPAD 320 DG425/DG525/DG725 NM-B321 Rev:1.0.The problem is turns on lights on the power button is present cpu is not spinning and no display, already tried reflashed with good bios and ec here in this forum but still same issue. i have attached the phone on the measurement of shorted coil and cap resistance coil is PL2202 and PL1401 and the cap is PC2251 I Dont have a schematic for this . anyone could help me solve this problem please
LENOVO 320 turns on lights present cpu not spinning
Tags: None
Re: LENOVO 320 turns on lights present cpu not spinning
Both the coil resistance is fine. Coils on CPU/GPU are supposed to show low resistance. -
cpu here is cold but turns on and the fan is not spinnngComment
I pulled up the possitive side of this cap becasue it goes to ground even i pulled up and back in it goes to ground does this short?Attached Filesif you find these attachements useful please consider making a small donation to the site
If the cap was shorted, coil will also shorted to gnd.Since you measured 0.04K resistance, so cap was simply not shorted. It may have shorted now 'coz you applied heat to remove it. These sort of caps has a tendency to go short when heated-so you should replace it. You are simply getting lost in trobleshooting it. When laptop is turned on, try to measure voltage on all coils and see which rail(s) is not rising and focus on that part.Comment
Better replace it with 330uf tantalum cap.Comment
Your problem is Vcore missing. What is the resistance on Pch Power coil(mostl likely the coil marked as 4R7 near batt connector. You need to check whether +3VS & +5VS is generated or not.Comment
resistance of the coil which mark 4r7 both sides have 17.99k when measuring it show 17.99 the goes to 0l both sidesComment
and the coil 4r7 has a voltage of 8.4v both sidesComment
Then it is likely charging coil and not pch power.Comment
You should check the basic signals like S5_ON,S4/S3_on, Sus,VR_ON,All sys pwrgood,pch power ok, ec rst Dram rst etc.Comment
Try this:
https://www.badcaps.net/forum/showth...80#post1217080Last edited by Vesko356; 05-01-2023, 09:13 AM. Reason: Attached schematic removed and replaced with link.Comment
Thanks @stevedb for the schematics. @mulong2019, since you have schematic, start measuring voltage .Comment
by bialagHello,
I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,... -
by gabrielA7Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
I saw that the room LED lights up only when the screen is connected, so quiet.
We have all the power supplies, even processor, 1.8V
One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
I suspect that there may be some leak in the processor.
Anyway, when I press the power, it... -
by twonk9098Hi all,
I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
I have tried a few new bios but exactly... -
by keepreadI've been using this laptop for quite some time w/o battery. It has Linux installed. Recently, someone sent me a web link in an instant messenger. When I clicked on that link the laptop turned off that instant, before the browser even loaded to open it. Since then it turns off several seconds after I start it up and log into the Linux graphical desktop. I can see the mouse cursor moving around the screen when I draw my finger on the touchpad or move the mouse, and then a terminal window begins to load because the desktop autostarts it from last time, and then I hear a pop from the speakers and...
by judamexI have a Lenovo Legion 5 Pro laptop - NM-D601 REV1.0 when I connect the battery it turns off after 5 minutes of use, if I don't connect the battery the laptop can keep working perfectly, I have already checked the charging voltages and they are fine, no I know if any mosfet is not working well, how can I know?
- Loading...
