MacBook Pro 820-3115 G3H missing
  • joesklar
    • Feb 2020
    • 5
    • England
    I'm new to the forums and was pushed in this direction based on recommendation from friends and also YouTubers in the repair community.
    Please excuse my ignorance as I'm new to Apple repairs.
    I've got a 820-3115 that I purchased as faulty. The laptop obviously had a repair attempt previously and there are signs of widespread liquid damage.
    I'm getting no PPBUS_G3H created on the board.
    I have PP3V42 across the board.
    My input voltage is around 16.6V at DC in. The schematic shows that I should be getting 18.5, is this something to worry about?
    After looking the machine over initially I came to the conclusion that I needed U7000 replaced for the OneWire circuit to function. After replacing U7000 I get a green light on the charger, but only for 5 seconds! The green light then disappears for a while and then comes back for 5 seconds.
    Again, I'm sorry for my ignorance here, but I'd really appreciate a push in the right direction.
    Thanks in advance for your help and I look forward to your responses!
    -Joe.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: MacBook Pro 820-3115 G3H missing
    16.5V is fine with a 60W Magsafe. Don't blindly trust the voltage indication on the schematics, they will almost always mislead you.
    Measure exact resistance to ground on PPBUS_G3H.
    • joesklar
      • Feb 2020
      • 5
      • England
      Thanks very much for the response.
      My resistance to ground on PPBUS_G3H is 0.840kΩ.
      • joesklar
        • Feb 2020
        • 5
        • England
        Just updating after some probing.
        Pins 27 and 28 of U7000 both have no resistance.
        C7030 and C7031 are also showing as short in diode mode.
        Q7085 does not open even though there is a lesser voltage on the gate.
        I hope this helps anyone who can make more sense of schematics than I can
        Thanks very much.
        • leovalpo
          • May 2014
          • 12
          • chile
          https://www.youtube.com/watch?v=dIuEYPOHlEU&t=1207s
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3578
            • slovakia
            Thanks very much.
            u did not add schematic or link to it so we cannot help
            • joesklar
              • Feb 2020
              • 5
              • England
              Hi there,
              Sorry for the delayed response, I've been busy with work.
              I've attached both the schematic and boardview
              • MtapeK
                • Sep 2020
                • 35
                • Zimbabwe
                Hi there,
                did you eventually solve your macbook's problem?
                • MtapeK
                  • Sep 2020
                  • 35
                  • Zimbabwe
                  i have the same model that does the same thing... but mine switch on with battery and not MagSafe... i would recoment you to to the same maybe you'll be shocked to see it actually power on then u might not need to replace U7000 after all
                  • envym
                    MacBook Pro 2018 with Activation Lock
                    by envym
                    Hi everyone!
                    I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                    I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                    06-27-2025, 08:54 AM
                  • salopian
                    Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                    by salopian
                    Hello. I would need some advice please.
                    My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                    He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                    I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                    I have already replaced the logic board with another...
                    02-27-2021, 07:30 AM
                  • mferna14
                    Apple MacBook A1398 820-00138-A missing 5V
                    by mferna14
                    HI all, I am working on Apple MacBook A1398 logic board # 820-00138-A. The problem is that it does not turn on & no fan spin. Board is very clean & no sign of liquid spill. Upon checking the initial troubleshooting power rails, I found that its missing 5V (Absolute 0V on the Coil L7720, no pulsing at all, it's just 0V). 3.3V is PERFECT & across all points on the logic board. Checked the IC U7501 pin 4, this pin should have the ENABLE volts to turn on the 5v rail, & P5VS4_EN is missing. This signal generated from U8170 pin 4. PM_SLP_S5_L is also not present & ALL_SYS_PWRGD is...
                    01-16-2023, 01:35 PM
                  • _Cupa
                    MacBook Air 2011 13" >820-3023 A< no power (PLT_RESET_L missing)
                    by _Cupa
                    Dear community,
                    this is my very first post, I am quite new to macbook repairs, and I am excited:-)
                    I have a 2011 MacBook Air 13' that does not power on. No fan spin, nothing.
                    Here are the specs:
                    MacBook Air Mid-2011
                    CPU: 1.7 GHz Core i5 (I5-2557M)
                    Model: A1369 (EMC 2469)
                    RAM: 4 GB
                    VRAM: 384 MB
                    The first question:
                    Unfortunately, it came with a 'fake' power adapter which seems not to talk to the computer. Sometimes it does show green light immediately after connecting it to the board,...
                    04-01-2021, 02:01 PM
                  • fajfelek
                    Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
                    by fajfelek
                    Hello, First of all thanks you for reading this topic.
                    I need your help with identify missing parts on trackpad logic board (661-18430).
                    The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
                    Please help me with identity parts from blue and red area .
                    06-15-2024, 01:41 PM
