Me analyzer setup help
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    I recently formatted my pc and installed win7 64 bit. I have installed python 3.8(latest)/ colorama -0.4.3/crccheck-0.6/PLTable-master/PyInstaller-3.6 and downloaded the latest MEA version R186.
    When i open any bios file it opens with minimal window and doesnt show many features like "ME State" etc. though it shows the basic stuff correctly.
    Where i'm going wrong?? Please guide me as the earlier setup was done by a guy who has already left the job with me.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Me analyzer setup help
    With prebuilt binaries you don't need to install anything else (Python and the libraries).
    ME Region has changed a lot between version 10 and 11. MEAnalyzer can only show "State" for version 11 or newer.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Thanks piernov for answering. I was actually analysing a bios which had me 10.x.x.x. Yup as always you are right. Tested with me 11.0 bios and it shows everything.
      • reformatt
        Create MEAnalyzer executable from Github Python Scripts
        by reformatt
        Each new release of ME Analyzer only has the scripts but no executable file. It's handy for me to just run the exe in Windows, so came up with the following guide for those that might want it. Didn't see anywhere else how to do it, apologies if it is documented somewhere and I've just missed it.
        ME Analyzer – create Windows executable from Python script from GitHub
        1. Install Python 3.xx from https://www.python.org/downloads/ – select to add Python to PATH during installation. Current version is Python V3.11.
        2. Open an elevated Windows Command Prompt...
        02-06-2023, 07:33 AM
      • pretendjury84
        Decrypt Keychain file
        by pretendjury84
        Sorry if this is posted in the wrong section.
        I need to decrypt a .keychain file. The methods listed on github (https://github.com/n0fate/chainbreaker) unfortunately dont seem to work. Im getting stuck on the first bit,
        1. Navigate to the directory containing the file setup.py
        2. Enter the command (from terminal): $ python setup.py bdist_wheel -d dist. This creates a wheel file (extension: .whl) in the /dist folder.
        qashifmasud@Qashifs-MacBook-Pro chainbreaker-master % python setup.py bdist_wheel -d dist
        zsh: command not found: python
        qashifmasud@Qashifs-MacBook-Pro...
        10-12-2024, 02:31 AM
      • Modify_inc
        Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
        by Modify_inc
        I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
        11-02-2021, 11:14 AM
      • quyet306
        Need CSME 18 Analyzer
        by quyet306
        Hello everyone
        Where can i find CSME 18 Analyzer?
        Thank all
        04-11-2025, 09:26 PM
      • notallbad
        Samsung UE55JU6000K stuck at 'Setup Conplete'
        by notallbad
        Reset the tv as internet connection not working, connected to router but no internet.
        Did a factory reset and completed the initial setup process but now just freezes on 'Setup Complete' page.
        Going into service menu it says 'Failure' at the top of the page and unable to access the 'control' screen.
        Its already on T-HKM6DEUC1570.0 fw.
        Are the SVC reset options likely to help here?
        options are
        apps reset
        svc reset
        spi flash reset
        data sync reset
        Any help appreciated.
        08-26-2023, 10:44 AM
