Imac A1312 (2011 )
  • arber1232
    • 377
    • Albania
    Imac A1312 (2011 )
    hi i have problem with back light for Imac A1312 2011 . i need help . i have 3.3 v in inverter for (EN1) and PWM and VIn 12 v .. in output i have 12v .
    Inverter at the output there should be 43 V .
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • worldofskin
    iMac A1312 2011 27" 820 - 2828 4mem Error Not booting to OS
    by worldofskin
    Hi guys. Hope you are having a great day. This imac iMac A1312 2011 27" with this logic board 820 - 2828. Came to the shop becouse it doesnt boot.I started the apple diagnostic and got 4mem error. I disassembled it, cleaned it and replaced the ram. For a little while it worked normally. But after a while it got to the same state. I tried changing all the ram with a good known working ones. Nothing, i tried a different drive to boot from, nothing. I tried to not boot from sata but i disconnected drive and connected only via usb. nothing. I tried to change the graphic card nothing. I dont have...
    11-03-2022, 05:07 AM
  • Wallybally
    iMac A1312 2011 27"
    by Wallybally
    I'm looking for info on what cap to get to put back on the mono of my iMax A1312 2011 27".
    It broke off the board when me and my stroke-riddled brain tried to put it back in the machine. I can't find the right board view schematics too. The symbols on the cap make identifying this one a bit difficult. I need some help here with what this thing is !
    Anybody ?
    I have it running Monterey, with the help of OCLP, and it even runs Logic too !
    I need it to run...
    Thanks !
    08-09-2022, 08:16 AM
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
  • slimmy182
    iMac 820-2507 A1312 27" 3.06Ghz C2D all USB delivering power but no communication
    by slimmy182
    I purchased an iMac 820-2507 A1312 27" 3.06GHz C2D with a hard drive issue. The operating system wouldn't load, but everything else seemed to be working fine. I tried leaving it powered on to reinstall the OS from a USB drive, but the hard drive completely failed. I suspect it short-circuited because it started getting very hot.
    I then opened the iMac and installed an SSD (without an adapter for the thermal sensor, which I left disconnected). After closing it up and turning it on, the computer loaded the operating system without issues. However, when I reached the login screen...
    02-07-2025, 05:08 AM
