overheating problem, maybe smsc problem?
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi good day I have a problem with this board it will turn on then after 5 min or more it will turn ogg beacuse of overheating I tried to change its board fan then trying outboard but smae problem.
    Maybe the problem is the smsc chip?
    EMC2112-BP-TR
    i think the chip will only hold up to 120c and my board is killing it up to 150c
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: overheating problem, maybe smsc problem?
    again SMALL PICTURES
    did fan turning on?
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        yes sir the fan is turning normal mode you can feel the air coming out but it still stud down beacause of overheating I already putted some thermal paste sir..
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          how did u know it is overheating?
          did u chceck with sw like speedfan?
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • Gibon378
            Problem with stopping audio and video for no reason
            by Gibon378
            PC Specs:
            • CPU: Ryzen 5 1600
            • GPU: GTX 1080 Palit JetStream
            • MOBO: ASRock ab350 PRO4
            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
            • PSU: XFX 650W (don't remember what model)
            • OS SSD: ADATA SP920
            • OS: Windows 10 21H2
            Problem description:
            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
            11-19-2022, 09:41 AM
          • perzyk23
            Lenovo T580 - LCD Panel problem - error 0288
            by perzyk23
            Good morning,
            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
            10-25-2024, 12:42 AM
          • lazaro.089
            Asus Zephyrus M16 / GU603ZW problem
            by lazaro.089
            Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
            CPU: Core i9-12900H
            Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
            Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
            The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
            08-26-2025, 06:33 PM
          • SDNarcia
            Dell 15R-5521 keyboard problem (KBC?)
            by SDNarcia
            Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
            As additional information,...
            07-20-2024, 10:47 PM
