lenov g50-30 power problem
  • hazim
    • Mar 2016
    • 62
    • egypt
    hi
    lenovo g50-30 ACLU9-ACLU0NM-A311 MB
    ther is a 3 fet short on mb
    PQ 303 P-CH
    PQ 311 N-CH
    PQ 312 N-CH
    AND ANOTHER ONE PQ 302 VERY HOT TCP8127 what's the equivalent for tcp8127 fet
    finally charger ic BQ737 what's the equivalent if it fault ?
    thanks
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: lenov g50-30 power problem
    TCP8127 is a P channel fet and you can replace it with 4407/4835/4409 or similar mosfets.
    Bq737 you can replace with BQ727 or BQ07A
    • hazim
      • Mar 2016
      • 62
      • egypt
      thank you so much i will replace
      • hazim
        • Mar 2016
        • 62
        • egypt
        fault was in
        pq 311 n
        pq 312 n
        pq 302 p
        i replace all and laptop power up ok
        thanks alot
        • Chieftain
          • May 2016
          • 72
          • Greece
          Nice mate..
          • classicandy
            • Apr 2018
            • 309
            • Nigeria
            I know this post is kinda old.
            Replacing BQ737 with BQ727 will make charging slow. BQ727 does not support Boost Charge (mode). HPA02224 is a better alternative.
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
            • perzyk23
              Lenovo T580 - LCD Panel problem - error 0288
              by perzyk23
              Good morning,
              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
              10-25-2024, 12:42 AM
            • lazaro.089
              Asus Zephyrus M16 / GU603ZW problem
              by lazaro.089
              Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
              CPU: Core i9-12900H
              Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
              Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
              The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
              08-26-2025, 06:33 PM
