Acer work on battery only
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Guys please help me with the following:
    Acer aspire 5742
    Compal la-6582P
    Work on battery only, if you plug the charge it doesn't charge, it doesn't power on with the charger.
    Here are photos along with the schematic
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Re: Acer work on battery only
    I have 19v on the first mosfet, on the second mosfet i have 19v on the source and 2.5v on the output which is totally wrong, the gate of the second mosfet is showing the same volt as the source which is 19v, this is a p-channel, the gate should be 9v or less...kindly assist guys
    • Techtiger
      • Oct 2014
      • 1602
      • france
      Check PACIN 3.3V what Voltage you get Drain PQ59B
      • mnciks11
        • Aug 2019
        • 345
        • south Africa
        I have 0v on PACIN
        I have 18v on Drain on PQ59B, and 0v on the gate of it
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Originally posted by mnciks11
          I have 0v on PACIN
          There are two easy ways to get through the way out , first one is reverse engineering Second his understanding the components think little bit I will give you the answer later
          • piernov
            • Jan 2016
            • 4439
            • France
            Cheeck if 1st DC-in MOSFET is shorted.
            • mnciks11
              • Aug 2019
              • 345
              • south Africa
              No the first mosfet is not shorted, there is no short, i even injected 19v with a power supply but still no short
              Lol please man what the way forward, i tried to jump the second mosfet on the dc in line using a wire, and yes i was getting 19v all over the board but still not turning on...only turn on when battery connected,
              What exactly is pulling 19v to be 2.5v on the output of the second dc in mosfet?
              Lol please please give me a hint then or a straight answer I've tried
              • Techtiger
                • Oct 2014
                • 1602
                • france
                1st makes sure 2Fets are not short after trace back PACIN pic i have send is a Beautiful Circuit made by Compel your charger IC pin15 VDDP helps to create PACIN & ACIN
                • survivalbloke
                  Acer Predator Helios 300 - will not power up if battery is CONNECTED
                  by survivalbloke
                  This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                  06-25-2025, 12:20 PM
                • dhs6512
                  Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
                  by dhs6512
                  Hello. Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 board
                  Initially dead. Inspection: the board was not touched, on EC IT8227E-192 2101-CXA there is a mini-burnout.
                  Replaced with the same one, flashed the EC with the official firmware (had to solder to the pins), left the main firmware (Gigadevice 25LB128DSIG) original.
                  When connecting the charger, the device started, gave picture and works, checked all the functions - ok.
                  Connected the original battery. Only on the battery the device starts for a second, lights up the keyboard backlight and turns off.
                  When connecting...
                  10-29-2024, 11:04 AM
                • ahmarzo
                  Acer TMX314-51 laptop battery problem
                  by ahmarzo
                  I have acer laptop tmx314-51 with part no 6050A3020501.
                  The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                  But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                  I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                  The schematic is not available...
                  04-11-2025, 09:14 AM
                • mkdj
                  ASUS X571 no power : battery issue?
                  by mkdj
                  Mark and model: ASUS X571
                  Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                  Tests already made:
                  - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                  - I have removed...
                  07-14-2025, 09:16 AM
                • pabloroggeri
                  Lenovo V310-15ISK - It doesn't work after changing the battery
                  by pabloroggeri
                  Good guys. I changed the battery to a Lenovo V310-15ISK.
                  The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
                  When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
                  08-23-2024, 12:01 PM
