Re: HP 15 LA-B972P problem with this matherboad
  • muzmail
    • Aug 2016
    • Pakistan
    Hi guis I have a problem with this matherboad, when I press power button the led on WiFi light on red and the indicator of battery at left light white for 3 -4 second and again power off. The fan are in stop and the display are black, Suggestion ? Thanks
    • 21955
    Have you tried another charger and RAM .
    • multimesut
      Dell 2007FPB Yellow Light Problem
      by multimesut
      Hello friends,
      A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
      11-13-2024, 07:00 AM
    • Tom_x
      HP Omen15 dc0001nh keyboard light problem
      by Tom_x
      Hi
      I have this HP laptop, board: DA0G3DMBCE0 rev:E
      The keyboard light only work, when i connect ac power supply(without battery), until the screen come with cmos checksum error. After this point light can't switch on. The first 5-6 seconds i can switch on/off light with FN+F4. When booing on, i can't switch on.
      Keyb light controller Y59116, i think working, because receive i2c commands the firsr 5 seconds
      I know schematic doesn't exist for this board
      Someone know similar board, that use this rgb keyboard light controller?
      regards
      04-05-2023, 10:32 AM
    • boyebaran
      hisense 65k560 back light problem
      by boyebaran
      hi to all
      tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
      in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
      please advise me tnx
      05-20-2025, 07:11 AM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • kity92
      Edifier x3 Earbuds Blue Light Problem (Charging Problem)
      by kity92
      I ordered a Bluetooth earbud one and half year ago, and right earbud broke. The light that should have been red when you put it in the charging case started to turn blue continuously(which means earbud is not charging) and after 1 week the earbud completely died. I disassembled right earbud because the warranty finished. I diagnosed the battery was dead, so I charged it with TP4056 and revived the battery.
      Right earbud is working now but I still didn't solve charging problem. I checked the charging box with a multimeter. There is 5V. I checked the headphone pins and they are working....
      01-13-2022, 01:49 PM
