Dell 3521 battre not charging
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Need help anyone have the schematic of charging circuit side the battery Dell 40Wh, any one knows how to reset cycle count circuit , test the battery 16V no leaking but no voltage on battery terminal , windows show 94% but not charging no fault in MB test the MB with another battery pack working ,
    The smart battery of a laptop has a circuit chip that keeps a cycle count number of times the battery has been recharged. Some manufacturers design their battery in such a way that it cannot be charged beyond a certain number of cycles, say 600 cycles (600 times). This is just for business as you have to buy a new
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Dell 3521 battre not charging
    There's no hard limit in cycle count as far as I know. Except that obviously the cells degrade and lose capacity, and at one point they can also fully short or only get surface charge (at that point when disconnecting the AC adapter the laptop shuts down instantly). Internal resistance can also increase so it cannot give enough current and the laptop shuts down under high load.
    However I don't see an issue with a battery that maxes out at 94%. It may recalibrate after a few full charge/discharge cycles, but if it doesn't no big deal. At 600 cycles it doesn't have its original capacity anymore anyway.
    In any case yes you can mess with the BMS, but no I don't recommend it. Never good to mess with batteries. Just for the knowledge it is possible to use a CP2112 breakout board and send SMBUS commands to the battery. Some tools like be2works make this easier, and they also integrate a bunch of unlock keys that you'll need to actually edit important parameters.
    • Techtiger
      • Oct 2014
      • 1602
      • france
      Thanka piernov
      i wll give try with CP2112 breakout board with be2works
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Thomasraud
        Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
        by Thomasraud
        i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
        QUOTED
        -It works on charger (without battery connected-only charger)
        -It works on battery (without charger connected-only battery)
        -& it also works when plugged in battery & charger, but it's not charging the battery
        //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
        and..
        QUOTE
        The IC cannot maintain the input current level
        06-28-2022, 06:47 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • Grucha98
        Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
        by Grucha98
        Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
        Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
        09-09-2024, 11:22 AM
      • Robocop
        Dell G3 3579 (LA-F611P) not charging
        by Robocop
        Hey guys,
        I've seen several questions about this exact issue, but I've never found the fix, so I would appreciate if we can start over the whole debugging process again from start to finish, for my specific issue.
        In the BIOS setup, (see pic) the AC adapter is detected with the correct power rating, the battery is stated as charging (when plugged in, of course), and the battery health is stated as "Excellent" (as expected, since this is a brand new battery purchased a couple of weeks ago). However, the battery never charges (the percentage never increases)....
        06-25-2024, 08:15 PM
