PPBUS_G3H fluctuating
  • Pedro147
    • Sep 2016
    • 157
    820-2879 green light on / PPBUS_G3H fluctuating from 12.61v down to 5.1v over a 6 sec time period and then straight back up to 12.6v and then repeats this. Short on an S3/5 rail ? If so how can I find it please? I am aware of diode mode and RTG measurements but not sure where to start looking. I have FlexBV and sch
    My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
  • Pedro147
    • Sep 2016
    • 157
    Re: PPBUS_G3H fluctuating
    No thoughts at all please ? ?
    Am I using the wrong deodorant ? ?
    • Pedro147
      • Sep 2016
      • 157
      I seem to be talking to myself here but here we go
      I found that U7200 was getting hot https://www.youtube.com/watch?v=bgehLziPNxM so I replaced it with one from a donor board.
      Now I have a steady 12.63v on PPBUS_G3H but some strange pin voltages on U7200.
      1 - 0v
      2 - 0v
      3 - 2v
      4 - 3.32v
      5 - 2.04v
      6 - 0.755v
      7 - 3.32v
      8 - 3.32v
      9 - 7.75v
      10 - 3.35v
      11 - 3.32v
      12 - 98.6mV
      13 - 3.36v
      14 - 2v
      15 - 0v
      16 - 12.63v
      17 - 5.03v
      18 - NC
      19 - 0v
      20 - 0v
      21 - 0v
      22 - 4.55v
      23 - 0v
      24 - 0v
      Is this of any help in moving forward please ? Thanks
      • piernov
        • Jan 2016
        • 4435
        • France
        What's the issue now? What are the "some strange pin voltages on U7200"?
        • Pedro147
          • Sep 2016
          • 157
          The 0v, 2v, 4.45v, 7.75v, 0.755v and 98.8Mv readings seem strange, but not really knowing what values these should have it's hard for me to know. Pin 15 is GND so that explains that I assume. Do these voltages look OK ?
          I am asking what rails I should be checking next please Piernov.
          I understand that this IC produces all the 3v3 and 5v power for the machine, and that it is a matter of other conditions being fulfilled to let logic gates to start allowing other rails to be produced IE, S5 > S4 >S3 > S0? There is obviously a logical choice of rails to check next but as yet I do not fully understand that logic and am after some direction please
          • piernov
            • Jan 2016
            • 4435
            • France
            My question was what are the symptoms of the machine now. Green light? Not turning on after pressing power button, fan not spinning at all?
            As for power rails, well, you said it yourself, you have to check them in S5→S4→S3→S0 order.
            Your measurements above already tell that PP5V_S5 and PP3V3_S5 are present but PP5V_S3 seems to be missing. But just extrapolating from that is not enough information to know what are the symptoms and what state the machine is in. Also always a good idea to tell what's the history of the machine.
            • Pedro147
              • Sep 2016
              • 157
              Of course, sorry about the sketchy info. Yes green light on, no 5v at fan connector, unknown history and no apparent liquid damage. I haven't tried to start by SMC_ONOFF_L to GND, should I ?
              • piernov
                • Jan 2016
                • 4435
                • France
                Yes you have to trigger power button to turn on the machine.
                • Pedro147
                  • Sep 2016
                  • 157
                  I didn't try seeing as there is no 5v at fan connector but I will try that after work. I assumed, possibly incorrectly that will not start if the fan isn't getting power? Thanks
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    But fan won't get power if the machine isn't turned on.
                    • Pedro147
                      • Sep 2016
                      • 157
                      Oh I thought that it would I am not the brightest - I need to watch more Paul and Louis videos Thanks I'll try after work
                      • Pedro147
                        • Sep 2016
                        • 157
                        Well I made a faux pas on Louis' Discord Macbook repair channel and got stopped from posting. I wasn't aware of the four mention rule when I was thanking you guys for your help. I might post the full text of that post here in case you still feel like offering any help Piernov
                        @friendly#6525 thanks. I don't mean to be a PITA forum hopper but piernov helped me out on badcaps forum this am (Aussie time) I was asking about my measured voltages on U7200. He asked me if I had tried to turn it on (by SMC_ONOFF_L ) This is where I got confused seeing as the 820-3330 has fan spinning without doing that as you have kindly told me.
                        I just turned this 820-2879 on and U1000 and U1400 started getting hot. I monitored for a 3v-0-3v pulse on PM_PWRBTN_L which I got not unsurprisingly. I disconnected quickly because I had the heat sink off to allow access during all the probing and chip replacement I have been doing. I just turned it on briefly again and I have 5v at fan connector but fan not spinning. Not sure if it's faulty (fan) or there is an issue with the PWM speed control? I assume that I cannot just test the fan by applying 5v and GND because of the PWM? It looks like there may be a voltage divider and a FET involved in fan speed control.
                        After I refit the heat sink (with thermal compound) I might check for a 3v-0-3v pulse on PM_SLP_S3_L and PM_SLP_S4_L
                        Any further clues greatly appreciated please guys and thanks for all the help so far @2informaticos @ChrisB @friendly @Inwerp and @piernov (hope I didn't forget anyone )
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          Apple Core 2 Duo machines need the power button to be triggered to turn on, they won't turn on automatically when Magsafe is connected with no battery.
                          If CPU and MCP are heating up, the machine is turning on, so it's reaching an S0 state and there's nothing wrong with PM_SLP_S4/S3_L.
                          Fan not spinning can be due to multiple reasons, but you should plug a speaker to check for chime and display to check for image.
                          I think you can apply 5V to the fan and it should spin (PWM left floating, should be pulled up inside the fan so should run at 100% when disconnected).
                          • Pedro147
                            • Sep 2016
                            • 157
                            Thanks Piernov I'll try after work and post back. Looks like I may be getting close
                            • Pedro147
                              • Sep 2016
                              • 157
                              I just realised that I forgot to finish my posting here. Well I got it going after Chris Busillo on the FB Macbook logic board repair group suggested replacing the U6100 ”BIOS” chip. Thanks for the help @Piernov
                              • Cemal Odabasioglu
                                MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                by Cemal Odabasioglu
                                I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                Observations...
                                01-14-2025, 03:54 PM
                              • triplefour
                                ONN 100012588 Has fluctuating Voltage on PSU 12v
                                by triplefour
                                Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                anyway i go to this guys house to look at an ONN 100012588
                                this is my first time looking at one of these brand of TV's.
                                TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                09-14-2022, 07:41 PM
                              • beetle1303
                                Wine Chiller - SMPS issue - fluctuating voltages
                                by beetle1303
                                My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                                Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                                Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                                Checking further on the primary side: Incoming line input to bridge...
                                09-04-2023, 10:33 AM
                              • beetle1303
                                Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
                                by beetle1303
                                Sharp TV flashing green light 2x per second at constant rate. Various reset methods do not have any effect on it. Search here and found flashing green 2x per second indicate bad power supply, which I am quite certain now.
                                I am seeking help with basic trouble shooting to find the short-circuit on the secondary side that I believe is the cause:
                                The main PD connector:
                                PD-1 (PNL12V) : 0.02V
                                PD-2 (PNL12V) : 0.02V (fluctuating)
                                PD-3 (SGRN) : 0V
                                PD-4 (SGRN) : 0V
                                PD-5 (UR13.2V) : 0.05V (fluctuating)
                                PD-6 (UR13.2V) : 0.05V (fluctuating)...
                                04-19-2022, 09:26 AM
                              • ronelex
                                Macbook Air A1466 Fluctuating 3v supply
                                by ronelex
                                Hello
                                I got this unit with orange light but wont boot up
                                I notice that its L7560 3.3v supply is fluctuating
                                this is the reading I got on its PWM U7501 TPS51890A
                                pin 4- EN1 - 0v
                                pin 12 - EN - 3.3v Fluctuate
                                pin 21 - EN2 - 3.3v Fluctuate
                                pin 22 - vreg3 - 3.3v ok
                                pin 23 - vin - 8.62V
                                pin 29 - vreg5- 5v fluctuate
                                I already check the power rails line in page 62 but I didn't find any short on those lines. I already tried replacing the pwm but same issue.
                                I hope you can guide me where I can look for the fault of this...
                                02-07-2023, 04:39 AM
