Asus ROG N501JW - dead
  • magneh
    • Apr 2014
    • 615
    • Portugal
    Hi!
    This is a funny one!
    Board is dead no sign of life, no liquid damage.
    19V are present, and I noticed a buzzing sound.
    Tracked it down to the IC PU8102 PWM CONTROLLER SN51285ARUKR
    TI QFN-20 , and he was also getting hot.
    I also noticed I had +3VAO but not +5VAO (no short though).
    Both enables to this chip are also low (0.06V something around that, also no short)
    As I had this chip, I replaced it with a new one, but still the same.
    Some more inspection and I found out the +3VA_EC line shorted. Injected some current and EC was getting hot. Ordered it and replaced it just a few minutes ago. short gone in +3VA_EC
    Plugged the charger. same buzzing sound from PU8102...and getting hot still. Disconnected charger, measured +3VA_EC shorted again...lifted EC, short gone... had another IT8585VG chip, replaced again. No short, doublechecked.
    Plugged, the charger, same thing, and +3VA_EC became shorted once again.
    What could be the reason to get the EC shorted each time I plug the charger?
    PU8102 is also a new chip, so kinda lost here...
    Anyone could share some ideas about this?
    Thanks!
    • 21883
    Re: Asus ROG N501JW - dead
    Is that a part missing ,or liquid damage on the gate of that mosfet.
    • magneh
      • Apr 2014
      • 615
      • Portugal
      Yes, its a cap missing, sound related. not important.
      No, just some dirt or flux.
      Any ideas about this EC constant shorting?
      • piernov
        • Jan 2016
        • 4439
        • France
        It's right on the gate of a MOSFET for a buck converter so I doubt it is sound related and I think it may be important.
        • magneh
          • Apr 2014
          • 615
          • Portugal
          Sorry! my bad, I was thinking this was the cap of another ROG board I was also analysing...
          This is a filtering cap for PQ9102,correct.
          PC9105
          But if im not mistaken, not critical, and not related with the power issue and EC constant shorting.
          • jasko_jacker
            • Oct 2014
            • 1140
            • italy
            PU8102 is a step down converter from texas Instrument TPS51285A,
            If you assert that the +3VAO exist, probably (other tests should be done)
            the problem is on +5VAO, try to isolate this line and check if the chip still heats up. If it doesn't heat up, you have various possibilities;
            one is to inject the 5 volts on the + 5VAO line and see if any component heats up.
            Each component must stay in place, even a component that seems unimportant for testing is better to be replaced.
            • magneh
              • Apr 2014
              • 615
              • Portugal
              If I am remebering well I think I injected 5v into that line and very little pozer consumption...but not sure I will doublecheck tomorrow
              When you mean "isolate the +5VAO line" , you mean removing the coil of +5VAO and then inject 5V?
              Ill let you know as soon as I take this board out for more testing
              • magneh
                • Apr 2014
                • 615
                • Portugal
                So when I assert 5V at point +5VAO the SN51285ARUKR PWM IC starts doing the buzzing sound.
                I get 40mA consumption and chip does not get hot.
                Ive done this WITHOUT the charger plugged in.
                Ive also doublecheked and +3VAO is 3V when charger plugged in.
                Ive still injected 3V at the +3VAO line, and I get 450mA consumption,buzzing sound and ITE gets hot... (without charger connected)
                Any ideas of what I could do next? kinda lost with this kind of behavior...
                or not worth it?
                • jasko_jacker
                  • Oct 2014
                  • 1140
                  • italy
                  If ITE is hot check for possible short or missing signals.
                  • magneh
                    • Apr 2014
                    • 615
                    • Portugal
                    Hello!
                    Ive replaced the ITE twice already, and the short goes away when I solder new chip back and plug the charger, short is back.
                    +3VA_EC is the line who is messed up regarding the ITE
                    As Ive replaced it twice with same results, what am I missing here?
                    • jasko_jacker
                      • Oct 2014
                      • 1140
                      • italy
                      If the short disappears without ite so the problem probably is on the power line but not 100%, if there is a short on the +3VA_ECC (check the picture 2 and check resistence first without cut the jumper if there is a short on this jumper follow the next steps:
                      the +3VA_ECC came from +3VACC on SL3006 , cut this jumper to isolate
                      +3VA_ECC from +3VACC and check both pins ..... see pics 2
                      • magneh
                        • Apr 2014
                        • 615
                        • Portugal
                        Thanks so much for these inputs!
                        Just some thoughts meanwhile.
                        Should I first removed the shorted ITE before doing those troubleshooting steps?
                        But even more important, Ive just measured the signals in the repair guide near the PCH, and Ive found out ME_SUSPWRDNACK also shorted!
                        I suspect this short will go away if I lift the ITE, as this goes to Q3002 and to the ITE.
                        I think I probed this point earlier on after replacing the ITE , and there was no short.
                        Thanks once again for all the help
                        • jasko_jacker
                          • Oct 2014
                          • 1140
                          • italy
                          You have to come up with a strategy for this repair,
                          Usually I try not to unsolder anything if I haven't found the problem, however at this point based on your data:
                          1 -> remove ite
                          2-> check resistance on + 3VA_EC
                          3-> if + 3VA_EC is in short isolate this line with precedent information.
                          4-> if + 3VA_EC is good, check ME_SUSPWRDNACK if this is in short,
                          , cut SL2212 and check short on pin 1 of this jumper
                          5-> if there is a short on pin 1 probably pch is dead to confirm, remove
                          R2213 and repeat measurement.
                          6-> if you don't find any short, clean well all ITE pads and power the board, measure the presence of +3VA_EC
                          7->if +3VA_EC is 3V , check resistence on ITE between it's GND and +3VA_EC (ite not in place) .....
                          • magneh
                            • Apr 2014
                            • 615
                            • Portugal
                            1 -> remove ite
                            Thanks for all the inputs.
                            1 -> Done
                            2 - > resistance 160k oHm , diode to gnd 0.44v
                            4 -> resistance 615 oHm at ME_SUSPWRDNACK
                            6 -> First difference when powering without ITE, the buzzing sound of the PWM IC SN51285ARUKR is no longer there, but I dont have +3VA_EC
                            +3VACC is also 0V. isolated these 2 lines at SL3006, and I have 660k ohm at +3VACC and 340k ohm at +3VA_EC
                            +3VAO is 3.3V and +5VAO is 0V
                            • noonly
                              • Dec 2018
                              I have this exact problem, did you ever find a solution?
                              • cyngo
                                • Jun 2015
                                • 219
                                • Indonesia
                                me too, any solutions ?
                                • TheWizard
                                  • Feb 2015
                                  • 190
                                  I also have the same problem. Traced 19v front to back of board. All present. But where the 5VA0 starts i have a short. Please let us know if you have fixed this and what resolved the issue.
                                  • mon2
                                    • Dec 2019
                                    • 14664
                                    Remove all power. Meter in resistance mode.
                                    Measure the resistance to ground of the power rail you suspect is shorted.
                                    Post the measurement.
                                    • TheWizard
                                      • Feb 2015
                                      • 190
                                      87.2 is the resistance to ground reading on +5VA0 entry point and pin 13 on SN51285ARUKR. (PU8102).
                                      • mon2
                                        • Dec 2019
                                        • 14664
                                        @ ~87 ohms to ground = shorted component, probably a capacitor.
                                        Do you have a DC power supply that can be dialed up to 1 volt (not higher) for injection?
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
                                        • Prott
                                          Gigabyte GTX1080 - identifying a dead short on vmem
                                          by Prott
                                          Hey!
                                          I have a problem with Gigabyte Aorus 1080. The card seems fine (expected resistance on vcore, pex, 5v, 1.8v, 12v and reset) except for a dead short on vmem (FBVDD). It's interesting failure mode, cause usually (in my experience) when memory fails it still retains a few ohms - this one is literally a dead short.
                                          I removed the inductors and tried inject voltage (0.8 V at 6 A) which only seemed to warm up the cables to the card while the card itself didn't show any hotspots.
                                          Is there any way to narrow down the search for a short? I would prefer not to remove...
                                          07-04-2023, 06:29 AM
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • JimMc0
                                          Gigabyte GA-H61M-USB3-B3 dead short 3.3v rail to ground.
                                          by JimMc0
                                          Hi there,
                                          I discovered this forum through a youtuber who teaches electronic repair. I've been trying to troubleshoot my dad's old PC which is a Gigabyte GA-H61M-USB3-B3 and will not power on. I discovered a dead short on the 3.3v rail at the ATX connector so I used a bench power supply to feed 3.3v into the ATX connector and sunk about 400mA into the board (I hope that's not too much!). I used a FLIR camera to identify the problem area:
                                          The chip seems to be the following, an ITE IT8892E 1108-CXS which seems to be a PCI bridge?
                                          03-27-2024, 08:36 AM
                                        • Mabot17
                                          ASUS gaming laptop GL704GV GPU DEAD SHORT
                                          by Mabot17
                                          Hello i need help to fix this laptop,at least a discrete to UMA conversion if it's possible.
                                          i took a photo of what i found,NVIDIA gpu side is 100% shorted as i desoldered power line coils and mosfet side is ok.
                                          Even without coils laptop still not power on.Main power rails,bios,1v,3,3v and 5v are present...
                                          05-10-2025, 11:04 AM
