Asus Laptop F552W with power issue
  • emmanuelbill1988
    • Mar 2017
    • 100
    • ghana
    i have this Asus F552W laptop a client brought for repairs which had a water spillage on the motherboard,after cleaning the board when you switch the laptop the power led comes on for 20 seconds and goes off again when processor fan is about to spin.
    can someone please help me?tnx in advance
    mobo number is
    X550EP
    REV.2.0
  • jrodefeld
    Asus laptop won't boot (no power) - possible bad caps?
    by jrodefeld
    I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
    The model:
    Asus Zenbook Pro Duo UX582L
    I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
    However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
    09-02-2024, 04:55 PM
  • yaya3gmax
    Laptop Power Issue – Works on Battery, Fails on Adapter Load
    by yaya3gmax
    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
    Symptoms:
    • Laptop works normally on a pre-charged battery.
    • Battery does not charge when adapter is connected.
    • Without battery:
      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
      • Speakers “pop” when power cut occurs indicating harsh sutdown.
      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
    08-21-2025, 07:16 AM
  • klopez0017
    Asus ROG Strix 17 (G733ZX) Laptop Power Issue
    by klopez0017
    I've had the laptop for about 2 years now, and lately, it has been acting weird whenever the AC adapter is plugged in. The issue is that when the AC adapter is connected, the charging often gets disconnected. This frequent connection and disconnection interrupts whatever activity I am doing, as it causes the laptop to underclock. At one point, the laptop even stopped charging with the AC adapter plugged in.
    When I try to use the PD in one of the USB-C ports, it charges just fine. The only downside is that I can only get about 100W of power since that's the maximum it can take, so...
    10-28-2024, 06:17 AM
    HP ProBook 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 430 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional...
    09-06-2024, 12:00 PM
  • wagolla
    Request for Assistance: HP Laptop with LA-G07FP Motherboard Power and Charging Issue
    by wagolla
    HP laptop with the LA-G07FP motherboard has encountered persistent issues with powering on and charging. Here are the details:
    1. The laptop does not power on or charge consistently.
    2. When I remove and then reinsert the battery, the laptop will turn on when connected to the power adapter, and the battery charges normally.
    3. However, after approximately 1-2 days, the issue reoccurs, and the laptop will not power on or charge until I repeat the battery removal process.
    4. I have already updated the drivers and BIOS via the HP support website, but the problem persists.
    Could you assist with...
    10-28-2024, 12:14 AM
