Chuwi Lapbook SE not starting (x2)
  • Iersuo
    • Oct 2015
    • 31
    • Ulu
    Uhhh... Quite a story with these Chuwi laptops.
    Bought 2 Chuwi Lapbook SE laptops. Great laptop... Until it stops working all of a sudden.
    First one worked a week until it just shut off and never came back alive again. Locals said it was the CPU, but could not explain how they tested. One of these did not even disassemble the laptop. Just connected a charger (their own charger) and came back telling that it was the CPU. He might have also connected something to the HDMI port, but I saw only from far away, so not sure. After all of the local workshops had to send the motherboard to the Chuwi factory for repair. Already a full month there and no results. Even no replies... Ridiculous service.
    Anyways the issue now is that the second laptop has now done the same trick. This time worked about 4 months. Wow...
    Completely dead. Only power connector LED lights up and I can hear ticking sound from somewhere off the motherboard. Ticking sound only when power supply is connected.
    Then suddenly turned on after disconnecting the battery multiple times and trying to boot different ways. Turned on and worked for 5 more days perfectly (though only with charger connected, battery percentage always showing 0%). All of this time distinctive coil whine while working.
    After the 5 days, in the morning just not turning anymore and this time I think for good. Nothing helps.
    Decided to check the batteries from both of the laptops. 2 batteries tied together to create a higher voltage battery pack.
    Designated voltage: 7.6V
    Max power: 8.7V
    Teared off the tape a bit to get to the battery pack control board and the contact points. EXPECTED to measure 3.8V off each battery cell (Thus 3.8+3.8=7.6V), but multimeter only showing 2.8V off each cell.
    Measuring off the contact points from the battery pack to the motherboard, not really getting any values... From any of the black wires to any of the red wires - 0V.
    Only value I can get is when the charger is connected, I am getting 3V from the yellow wire to the red.
    Also one chip (power regulator I think?) gets hot very quickly as soon as the charger is connected.
    Any ideas where to look? Battery packs dead?
    Power regulator gone bad? Hard to distinguish, but might be the source of the ticking sound
    Really the intel CPU as they said? I always like to monitor temperatures in my laptop and CPU never gone over 75°C. Normal usage ~60°C. Would be weird to have 2 INTEL cpus dead so quickly
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Chuwi Lapbook SE not starting (x2)
    That's a dead battery or at least deeply discharged. Be careful with LiPo batteries as they can be very dangerous, better not mess with those.
    Which chip getting hot are you talking about?
    • Iersuo
      • Oct 2015
      • 31
      • Ulu
      Would definitely be good if the only problem is the battery. I can order a replacement, but it is quarter the price of the whole laptop, so want to know 100% if that is the issue, or is it something in the charging circuit.
      Is it so that these ultrabooks do not turn on without a battery? Used to those older types, that you can run with the charger plugged in. These cannot do it?
      This is the hot chip in the attachment picture.
      Markings:
      iTE
      IT8987E
      1833-BXS
      S162VB
        • 20758
        For the first laptop they probably tested the usb data lines to ground,a full short would mean a dead pch if they`re directly connected .
        • piernov
          • Jan 2016
          • 4435
          • France
          IT8987E is the EC (Embedded Controller). Usually EC getting hot = dead EC.
          • Iersuo
            • Oct 2015
            • 31
            • Ulu
            Found a few coils with 0V power. Any ideas how to troubleshoot further? Clearly something with the power delivery?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Those coils with 0 volts are most likely vcore coils for cpu. I think you should forst replace the EC and then proceed further. Remember, this ec is programmable.
                • 20758
                Edit: dead link removed
                • Andre Kinetic Dimension
                  • Feb 2019
                  • 7
                  • Portugal
                  hi!
                  Can we get a new link for these files? that one in previous comment is dead!!!
                  • Aleix
                    • Feb 2023
                    • Spain
                    Hello, my chuwi lapbook pro got a brick, I think, after bios renewal, now on starting the device, there is a blinking of the power light and nothing more, can anybody help me? Thanks in advance!
                      • 20758
                      Originally posted by Andre Kinetic Dimension
                      hi!
                      Post your bios backup in the "Bios requests ONLY!" section and someone will help https://www.badcaps.net/forum/forumdisplay.php?f=40
                      • master_haze86
                        820-01958-A no power sys led = white when charger is connected.
                        by master_haze86
                        Hi everyone.
                        First, let me preface by saying that I do not have much experience with diagnosing damages in motherboards other than visual inspection and checking simple short to ground faults.
                        But I do learn quickly, and really want to learn how to properly diagnose motherboard faults. If someone could have the patience to go over this board with me, it would be greatly appreciated.
                        A customer came into my shop with a A2179 MacBook with an 820-01958-A logic board. The reason for bringing the laptop in is that the laptop stopped turning on.
                        First thing...
                        02-15-2024, 05:30 PM
                      • motormayhem
                        Lenovo T460 Only Charges on One Charger
                        by motormayhem
                        Laptop Question
                        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                        05-12-2023, 01:46 PM
                      • nikolayu
                        Dell Latitude 5420 wont turn on when charger is connected
                        by nikolayu
                        I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
                        Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
                        The same thing if I connect to other USB C port.
                        Charger is OEM
                        03-13-2024, 12:34 PM
                        NVDC charger configuration...
                        11-05-2024, 03:28 PM
                      • flat-earther
                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                        by flat-earther
                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                        Windows also shows ''Plugged in'' when charger is not connected.
                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                        If I let battery run out and say it has 3% Windows will...
                        06-24-2025, 09:32 AM
