HP 6510b display backlight blinking and laptop shuts down
  • Iersuo
    • Oct 2015
    • 31
    • Ulu
    Hello! Straight to the issue:
    Laptop working perfectly every day, until...
    One morning it just does not work properly anymore...
    Screen blinking (the backlight CCFL) randomly during the boot up process. Screen is definitely working, as everything can be seen, though very dim.
    Video of the issue:
    https://youtu.be/TJ8Lvba5peM
    Any ideas how to troubleshoot this at least to some precision? Flex cable? Inverter board? CCFL bulb?
    Have only a multimeter for testing, basic knowledge and a lot of will.
    Would like to know what exactly to order. Inverter board looks otherwise ok, but one capacitor(?) looks like it has had better days at the soldering points. Pictures attached.
    • 21960
    Re: HP 6510b display backlight blinking and laptop shuts down
    Resolder the cap,use plenty of flux.If it still doesn`t work replace the inverter.Don`t try to test the output voltage,it dangerous,the voltage is very high.
    • Iersuo
      • Oct 2015
      • 31
      • Ulu
      FIXED
      Resoldered the cap / resistor? Did not help.
      Accidentally realized that the source of the problem was a faulty backlight switch / lid closure sensor. The little black switch just below the display connecror in the attachment photo. Due to age it started failing, making the laptop think the lid is closed / open / closed / open...
      Due to lack of rime for a proper fix, I completely removed the internals of the switch. The laptop does not recognize closed lid state anymore, but at least the display works now perfectly, which is all I need from this laptop of such age.
      Thanks for input!
      • ahmarzo
        Hp 15-cs laptop 5 times dc jack blinking white
        by ahmarzo
        I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
        First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
        Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
        But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
        12-28-2024, 04:46 AM
      • ronaldo17
        Power button blinking, Laptop Hp pavilion gaming 15-ak DAX1PDMB8E0 rev E
        by ronaldo17
        When I press the power button, nothing happens. All I can see is the power button blinking and never stopping.
        Here’s everything I’ve tried:
        -Removed the battery
        -Changed the power adapter
        -Replaced the CMOS battery
        -Changed the RAM.
        But my laptop is still blinking. However, in the morning after I wake up, the laptop will turn on.
        Here is my spec:
        -i5 6300hq
        -Gtx 950m
        -Hp pavilion gaming 15-ak030tx Laptop DAX1PDMB8E0 Rev E
        Now, I'm trying to fix the motherboard using the schematic I found
        If anyone can help...
        08-25-2025, 09:02 PM
        Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
        This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
        09-06-2024, 09:30 PM
      • giliy52480@degcos.com
        Surface laptop 4 1951 no disp backlight on
        by giliy52480@degcos.com
        This surface laptop had a backlight flickering. I put some heat on the edp socket and some capacitors around (I think cold solder occurred) the socket, but after some days the problem came back. Then, immediately after turning it on, the system firmware update appeared(black screen with bar ), and during the test(press hand on the socekt) for the edp connector, whether it was broken or not, the system turned off (because when press on camera socket the backlight is got ok) and finally, when it turned on, the backlight was on, but no disp. When I pressed the F4 key to go to the bios, the display...
        01-05-2025, 03:38 PM
      • RdeveLabs
        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
        by RdeveLabs
        To all the members here...
        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
        05-05-2025, 04:59 AM
