Dell Latititude ic equivalnt
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    hi im searching for equivalent chip of 1285b, i can't find exacty the same
  • u666sa
    • Jan 2014
    • 87
    Re: Dell Latititude ic equivalnt
    TPS51285B was replaced with RT6575A
    on Compal-La-9591P
    Interesting that doing a search on aliexpress for TPS51285B gave me a boat load of results ranging fro $2 to $5 bucks for 5 pieces from china with free shipping.
    Doing same search on amazon resulted in 10 pieces lots for about $10 to $20 on average.
    I bet you can also find them on chip dip and other sites if you search properly.
    • digitalpc
      • Jun 2016
      • 305
      • .DLL
      i can't find, but i try some ic-s which have same pins base in datasheet and doesn't work
      thank you anyway
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
