Dell 3521 7 beeps and no display
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys
    Im current working on the Dell
    VAW00 LA-9104P
    Rev : 1.0
    Measurements:
    I have all other necessary volts
    The Gfx core is missing, 0v.
    Fan spins constantly
    I changed the bios chips both of them with another same board but still no lucky
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell 3521 7 beeps and no display
    Check PU400 requirements or replace this chip if you have difficulty in measuring. Be very careful-your probes should be needle sharp.
    • mnciks11
      • Aug 2019
      • 345
      • south Africa
      Okay let me do it now coz i have another replacement chip
      • mnciks11
        • Aug 2019
        • 345
        • south Africa
        I changed the chip but still no lucky, let me put another one and see
          • 21907
          Did you clean the ME firmware on the original bios, or on the replacement bios.
          • mnciks11
            • Aug 2019
            • 345
            • south Africa
            No I didn't
            • ayooon_2010
              • Sep 2015
              • 33
              • cairo
              check cpu circuit . after change cpu
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Cpu is onboard soldered and dont change it without being sure.
                • kiraro
                  • Jan 2016
                  • 177
                  • North NY
                  Remove PJP1100 and PJP800, see if the mb post or changing beep code.
                  • abderrahimfouad
                    • Sep 2021
                    • 20
                    • morocco
                    same problem bro
                    • lapfix
                      • Mar 2020
                      • 2764
                      • my workshop
                      Originally posted by abderrahimfouad
                      same problem bro
                      Bios can make this issue, dump io too
                      pu 500 pin1 voltage
                      uz1 voltage
