Touch issue on Surface 3 1645 model
+ More Options
Posts
  • JG2018
    • Jun 2018
    • 38
    • Belgium
    Replaced the screen of a 1645 Surface 3. With the new screen installed, touch of screen seems to work as when i touch it i can see the little point following the finger movements but once i want to select a folder or change it place, the touch doesn't seem to do its job.
    Have exact same issue on 2 different same model tablet. It the screen defective or do i need to calibrate it?
    Do you already faced this weird issue?
    Not used to Surface repairs.
    Thanks for your help.
  • KvnTM
    • May 2018
    • 434
    Re: Touch issue on Surface 3 1645 model
    Run the Surface Diagnostic tool first:
    https://aka.ms/surfacerepair
    This contains a touch screen test. Maybe it's just a driver/configuration issue.
    Was the old screen cracked and did you get a oem replacement?
    • JG2018
      • Jun 2018
      • 38
      • Belgium
      Hi thanks for your input.
      Ok will run it and let you know.
      Yes old screen was simply broken got a part from confirmed supplier but our tablet is model 1645 and he send 1657 but it seems to be perfectly compatible screens, no?
      • KvnTM
        • May 2018
        • 434
        Screens are identical between these models. Run the test and let us know
        • Gabriel Lucas
          microsoft surface pro 5 touch screen not working
          by Gabriel Lucas
          Hello everyone, I bought a Microsoft Surface Pro 5 and the touch doesn't work. According to what the previous owner said, the screen stopped working after an update. The screen has no physical damage, and the touch works for 1 second when it turns on and then stops working. I've tried updating the drivers, formatting, and returning to factory defaults, but nothing worked. Can you help me?
          02-18-2025, 09:24 AM
        • iprotech
          Surface Pro 5/6 Touch Issue
          by iprotech
          Started with a surface pro 5 repair with battery not fully disconnected and ended with dead touch. Tested with a new touch module and new cable and there still is no touch.
          Measured touch power rails 1v8 and 5v, both are present.
          From schematics and boardview it seems like everything happens over SPI, the i2c is NC
          The MOSI goes directly to the CPU through a 10ohm resistor
          MISO also goes to CPU through a 10 ohm resistor but also goes through some buffer/level converter chip (VC125) for SPI sniff im guessing for panel brightness level.
          I do not have a scope,...
          05-01-2024, 12:54 PM
        • hotgly
          Surface Pro 9, i5 version, lost touch on screen after upgrading hard drive, and ISH Power State shows Disabled
          by hotgly
          After upgrading the factory 128Gb SSD to a 512Gb WD_Black SN770M, this surface pro lost touch on screen, no touch in windows or in UEFI.
          The Human Interface Devices did find touch and stylus but it shows Disabled in windows device manager.
          I am not sure if this is a bios problem or hardware problem, already tried reinstall and reset from windows, not working. And now trying to clean/reset the bios.
          Computer model is: Surface Pro 9, i5, 8GB memory, 128GB
          Serial number: 0F00S2Y22353BF
          Intel(R) ME Code Versions:
          BIOS Version 12.200.143
          MEI Driver...
          05-15-2024, 02:20 PM
        • Yehuda170
          ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
          by Yehuda170
          original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
          replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
          now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
          with original broken screen i can see in device manager touch screen in human interfaces
          but with the new screen it's not showing in device manager
          is it lenovo blocking it? is it driver missing?
          I²C is a headache
          07-14-2023, 01:29 AM
          Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
          This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
          09-06-2024, 08:10 PM
