Strange behavior on the proline laptop
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello my lovely brothers
    I'm facing a strange behavior here, the laptop comes up and quickly shut down.
    When i remove the ram it cones on and the green light stays and doesn't shut down, I changed the ram and inserted another ram it still doing the same thing.
    I checked the ram power supply there is no short to ground
    Measurements are:
    -Ram power supply = 1.5v
    -Cpu power supply = 0.0v
    Motherboard number it = 6-71-W24Z0-D02A I dont have the schematic
    • 20795
    Re: Strange behavior on the proline laptop
    Schematic. https://drive.google.com/file/d/1mdu...uNfbbodo-/view
    Bios. https://repo.palkeo.com/clevo-mirror/W2xCZ/
    • mnciks11
      • Aug 2019
      • 345
      • south Africa
      Thank you so much brother i will update you all if I managed to solve this
      • mnciks11
        • Aug 2019
        • 345
        • south Africa
        Hello guys please clue me up here on this machine, here my finds so far
        I Have 1.11v on the vcore, and the gate on one of the mosfets for vcore power supply is 0.007 when compared to ground.
        One more thing i have 0v on the gfx core
        The laptop keeps on turning On and quickly shuts down after pressing the power button
        Any clue guys, why the value of the gate is so low if compared to ground? Is this normal
        • KvnTM
          • May 2018
          • 434
          The switching on those fets is really fast and your meter probably isn't picking it up correctly. Get a scope if you have one and look at it.
          0v on gfx core is most likely your problem. Whats the resistance of gfx core to gnd?
          • mnciks11
            • Aug 2019
            • 345
            • south Africa
            It 004 using continuity mode
            • KvnTM
              • May 2018
              • 434
              Resistance please.
              • mnciks11
                • Aug 2019
                • 345
                • south Africa
                Resistance please.
                How?
                What range should i set on my multimeter please help
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  How?
                  200 ohms
                  • mnciks11
                    • Aug 2019
                    • 345
                    • south Africa
                    200 ohms
                    It 04.8
                    • KvnTM
                      • May 2018
                      • 434
                      It 04.8
                      Thats fine.
                      What do you get on Pin 4 (VR_EN) of PU1?
                      Please measure while powering the board. It should go high when the board turns on.
                      • mnciks11
                        • Aug 2019
                        • 345
                        • south Africa
                        Thats fine.
                        Yes i did, i get 3.25v
                        The board is still doing the same thing, powers on and quickly goes off
                        I checked all the power supplies, they are all okay, 5v is okay, ram volts is okay i have 1.5v on the ram chip and coil, pch power supply is okay .
                        If i remove the ram it powers on and never shut down but obvious no display and doesn't post
                        • mnciks11
                          • Aug 2019
                          • 345
                          • south Africa
                          Can i have the list of things to check so that in feature i will know what to check guys and give you proper information.
                          • KvnTM
                            • May 2018
                            • 434
                            Now check
                            Gate & Drain voltage on PQ108, PQ109
                            Gate voltage on PQ110, PQ111
                            There is no universal guide for troubleshooting something. But usually you always check all power rails before doing anything else. That will give you a clue of what is going on.
                            Power rail missing? => Fix it.
                            All power rails present and everything should be ok but no post? => Bios or dead CPU
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Going by my experience, your sio chip is bad. Replacing it will solve your problem.
                              • mnciks11
                                • Aug 2019
                                • 345
                                • south Africa
                                Thank you i have to find the chip and update you
                                • mnciks11
                                  • Aug 2019
                                  • 345
                                  • south Africa
                                  Now check
                                  All gates have 0V of PQ110, PQ111, PQ108,PQ109 i have 0v on their gates, the Switching mosfets do receive 19v but they don't switch, they are not being told to switch
                                    Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                    This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                    09-06-2024, 09:30 PM
                                    Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                    This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-06-2024, 08:47 AM
                                  • RdeveLabs
                                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                    by RdeveLabs
                                    To all the members here...
                                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                    05-05-2025, 04:59 AM
                                    Microsoft Surface Laptop Surface Laptop Go 2 Notebook Go 2 Specification for Upgrade or Repair
                                    This specification for the Microsoft Surface Laptop Surface Laptop Go 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop Go 2 boardview and Surface Laptop Go 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-07-2024, 06:11 AM
                                    Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                    This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
