Aa15 la-d071p rev 1.0 not charing
  • kalilinux25
    • Mar 2018
    • 2084
    • ZAMBOANGA SIBUGAY
    The dell laptop wot charge the battery Ive tried to replace its battery and charger now I think the problem is on the board
    Measuring PR765 im getting 0 voltage that in the schematic I should have 17v
    ive check the charger port form the midle pin its OK
    because some of dell charger the charger port can get damge easily ..
    what to do next ?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Aa15 la-d071p rev 1.0 not charing
    You are not getting +17.4V_BATT+ on PR765 and there could be 2 reasons:
    01. Batt is deeply discharged/dead
    02.You charger ic's high/low fet's gate not opening.
    Does it give any adapter warnings?? Charger detected in bios setup??
    • kalilinux25
      • Mar 2018
      • 2084
      • ZAMBOANGA SIBUGAY
      I didnt have any warning in the bios it will jus t boot on windows then looking at the battery icon battery not charging
      The led indicator keeps on flashing orange , even Ive change its newly battery from a working same model
      • dilip.pawar31
        • Nov 2014
        • 59
        • india
        pls check psid singnal first
        and wattage showing or not pls check in bios
        • kalilinux25
          • Mar 2018
          • 2084
          • ZAMBOANGA SIBUGAY
          I only have digital tester sir maybe it need OSILOSCOPE
          • piernov
            • Jan 2016
            • 4435
            • France
            Does it show battery percentage correctly and does it run from battery with AC adapter disconnected?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Neither dmm nor scope is needed to check. just press F2 and go to relevant section and see it detects the adapter or not.
              • kalilinux25
                • Mar 2018
                • 2084
                • ZAMBOANGA SIBUGAY
                It shows battery is in 40% but not charging
                • kalilinux25
                  • Mar 2018
                  • 2084
                  • ZAMBOANGA SIBUGAY
                  The adapter is detected sir beacuse I can power on the unit without the battery I go to the bios
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Powering on a unit only on ac adapter doesnt means adapter is detected. However, in your case it is detected as it shows it 65W correctly.
                    • kalilinux25
                      • Mar 2018
                      • 2084
                      • ZAMBOANGA SIBUGAY
                      What the next thing to do sir?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        DAT_SMB,CLK_SMB,SYS_PRES-Measure these signals present or not on battery connector. Check PQ704/708 as well.
                        • flat-earther
                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                          by flat-earther
                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                          Windows also shows ''Plugged in'' when charger is not connected.
                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                          If I let battery run out and say it has 3% Windows will...
                          06-24-2025, 09:32 AM
                        • motormayhem
                          Lenovo T460 Only Charges on One Charger
                          by motormayhem
                          Laptop Question
                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                          05-12-2023, 01:46 PM
                          NVDC charger configuration...
                          11-05-2024, 03:28 PM
                        • Johndill
                          Dell Inspiron 7567 LA-D993P odd charger issue
                          by Johndill
                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                          Here are the tested scenarios:
                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                          11-16-2022, 10:55 PM
                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                          Narrow VDC applications where the system power source is
                          either the battery pack or the regulated output of the charger.
                          This makes the max voltage to the system equal to the max
                          battery voltage instead of the max adapter voltage. Operating
                          at lower system voltage can improve...
                          11-05-2024, 04:43 PM
