lenovo t430s no power
  • kammy6000
    • Oct 2012
    • 22
    • uk
    hello, i have lenovo t430s since can not get schematics closest is t430 schematic but i have check all the fuses and all seem ok
    but not powering on at all no led power light no nothing
    this board has separate power sub board and look like have burn mark on some the copper lines where it connects to mainboard but still connecting ok , 19v reaches fuse f2
    connected to powersupply and not drawing any amps at all
    power button is on keyboard on this model
    i also notice the sub power board have little switch like a push switch maybe its does nothing probably
    any help please
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: lenovo t430s no power
    check the voltage on fet Q36 Q9 all legs Drain/Source/Gate find out the voltage of ACDC ID Schematic T430
    • kammy6000
      • Oct 2012
      • 22
      • uk
      hello thanks for reply
      Q36 mosfet has on 4 legs 0.02 0.02 0.03 0.02 and gateside has 0.83 on both connection
      is it died?
      thanks
      • Techtiger
        • Oct 2014
        • 1602
        • france
        check fet Q9 all legs most pro 1st fet not switching on +19V check for short with out power in DIODE mode
        • kammy6000
          • Oct 2012
          • 22
          • uk
          ok on the first fet i get resistance 567 all 3 legs 4th leg 0.00
          on second fet no resistance on any leg , so this means ? thanks
          • peste
            • 13550
            • ROMANIA
            From the picture,chip bridge network NS692412 SOP24, seems to have problems.
            • kammy6000
              • Oct 2012
              • 22
              • uk
              yes you right this has been removed because it was dead and laptop not have any Ethernet connection but this problem happened after that because this board has subboard so the sub board came loose while power was applied i think that damaged a chip somewhere causing the power issue
              • kammy6000
                • Oct 2012
                • 22
                • uk
                this is other side sir
                • digitalpc
                  • Jun 2016
                  • 305
                  • .DLL
                  check first 2 mosfets any short or voltages?
                  • kammy6000
                    • Oct 2012
                    • 22
                    • uk
                    ok so Q36 is shorted as gets warm and dissolves alcohol fast thanks
                    • springer
                      • Mar 2018
                      Yes my t430s had same issue. Q36 got hot to touch. And output of Q36 was shorted to ground. However, looking at schematic, there was no way for Q36 itself to short to ground directly. So something tied to output of Q36 was shorting to ground. In my case it turned out that one of the big caps (C234) was physically deteriorated looking and was also hot to touch. Once C234 was removed, short on Q36 disappeared resolving the issue.
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • Powderfanupnorf
                        Dell AL440LX power on switch circuit help required
                        by Powderfanupnorf
                        Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                        So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                        My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                        06-24-2024, 01:24 PM
                      • grimacelord
                        NEC TurboExpress On/Off Power Switch Replacement Help
                        by grimacelord
                        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                        11-09-2023, 09:49 AM
                      • Mufasa
                        Lenovo Yoga 6 Power Switch Board Parts Identification
                        by Mufasa
                        Hey peeps,
                        I have a Lenovo Yoga 6 with a smashed in switch module. All I need is a replacement switch and not the entire board. Does anyone know a likely candidate from another Yoga laptop or a vendor who most likely has the replacement needed? ...
                        10-18-2024, 06:28 PM
                      • Dr.d
                        Help please..Lenovo ideapad 5 14itl05 power and charging problem
                        by Dr.d
                        I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                        Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                        04-05-2024, 11:48 AM
