Dell 15-5567 turns on automatically from battery
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Modelell Inspiron 15-5567
    Platform:LA-D802P rev 1.0
    Problem: Laptop works fine with charger and with charger+battery(both connected). However, gives trouble with battery only.
    When you connect the battery(while ac power removed)-everything is fine-you can turn it on and there is display. But once you turn it on from battery and you turn it off(from bios setup/windows)-it shuts down perfectly but turns on within next 30 seconds. This doesnt happen with only ac power, and AC+batt connected together. happens only on battery alone.
    01.Power switch is not the issue as i'm switching the board directly by shorting to gnd.
    02.Flashed dell virgin bios(main 16mb). have not touched/flashed microchip as i fear this sio as it has bootloader.
    03.No corrosion,liquid damage.
    04.DC in fet and battery output fet are ok.
    05.Windows issue ruled out as the problem persists even shutting from bios without hdd connected at all.
    Honestly, I've never experienced this before and have no idea about the probable causes. It has internal battery and another battery is not available with me. battery health shows excellent in bios and it charges/discharges well.
    Any ideas friends??
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Dell 15-5567 turns on automatically from battery
    Same when putting to sleep?
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      I had many laptops that used to automatically start when we connect AC power or Battery for the first time or when the mainboard is out of the laptop. Then, when I reassemble the laptop and connect everything to the mainboard, the auto-start problem will be gone after a few number of starts and shut-downs.
      If this is not the case, I think you have to do a real-time tracking of control signals on the mainboard.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        probably an unexpected signal gets on between the battery, the SIO, and the charging IC.
        For example, I have an external Fax modem connected to my desktop PC. when the PC is off, if I turn the Fax modem on, then the PC starts automatically. I mean even a signal from a modem can turn a PC on.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          yes
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Thats wierd but will give it a a try.
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • HTR-Informatique
              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
              by HTR-Informatique
              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
              I also changed the screen because the PC fell and the screen was broken.
              I changed the battery with a new and original battery.
              I also had corrosion/oxidation on the...
              02-09-2025, 06:51 AM
            • danielsak
              Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
              by danielsak
              Hello, I have issue with Dell Inspiron 3542.
              Motherboard marking:
              Code:
              PWB FX3MC REV: A00
              The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
              1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
              1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
              10-11-2024, 04:36 PM
            • ipatch
              dell inspiron 5567 laptop battery lipo WDX0R
              by ipatch
              recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
              1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
              2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
              got the computer...
              04-02-2023, 04:45 PM
            • tomodachi
              Dell Precision 5510 " Not a Dell Battery"
              by tomodachi
              Hi
              Dell Precision 5510
              Mobo code : LA-C361P
              This one came in for battery replacement but without original battery, so original battery and charging history is unknown.
              The customer said he bought the computer several years ago second-hand and was told that there was no battery inside but that he could purchase one if he wanted.
              So we ordered a geniune battery for customer, plugged it in
              RTC battery was also dead and it was also replaced. First boot up brought up warning message;
              Funny thing is Service Tag is already set.
              And...
              11-07-2024, 06:08 AM
