LA-B843P Rev 1 2beeps
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Friends need help
    MB LA-B843P Rev 1 with 2beeps code error all Coils Voltages are ok SOC CPU PCH ect , in Ram slot
    pin 30 DRAMRST 0.27V this is the fault
    pin 203/204 VTT0.68V
    pin 75 VDD 1.37V
    pin 200/203 3.3V DATA CLK
    i tract it back but could find R410 C1301 but i trace it back up to PCH line same voltage 0.27V
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: LA-B843P Rev 1 2beeps
    Schematic https://www.badcaps.net/forum/showthread.php?t=66749
    • piernov
      • Jan 2016
      • 4439
      • France
      It has to detect memory through SMBUS first. Make sur eyou're using known good compatible RAM stick DDR3L. Also make sure you tried with touchpad disconnected.
      Then measure diode mode to ground on the SMBUS SDA/SCL lines
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Q1201/1202 probed?? Bios flashed??
        • Techtiger
          • Oct 2014
          • 1602
          • france
          i have 2beeps with or with out RAM change stick same issue SDA diode mode 498 SCL in Diode mode 575
          Q1201 S 1.36V D 4.08V G 1.36V
          Q1202 S 1.36V D 1.29V G 4.08V
          i havent flash BIOS yet do you think this is BIOS issue ?
          • piernov
            • Jan 2016
            • 4439
            • France
            Usually SCL and SDA should measure within 1% of each other in diode mode to ground.
            Could be BIOS too.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              yes, have seen DRAMRST missing due to bios on many platforms. Eg dell cedar 13269-1 intel motherboard. So will strongly suggest to flash bios first.
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Could be BIOS too.
                i will flach BIOS and update
                • j4rzyn
                  • Mar 2020
                  • Poland
                  Did you solve your problem. I have same issue with same board. 0.12V on DRAMRST - pin 30 of DDR slot. Ive try 3 different BIOS dump.
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    Trace it down to SOC and put a jump Voilà
                    • limpidity
                      • Sep 2019
                      • 49
                      How did you jump?
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        Originally posted by limpidity
                        How did you jump?
                        What is the issue with the board DRAMRST missing ? if so check R410 for voltage on both side ?
                        • limpidity
                          • Sep 2019
                          • 49
                          There was a problem with the resistance, so I replaced it, but the symptoms remain the same
                          The DRAMRST# voltage is 0.125v, approximately 0.67kOhm when measured by the tester as shown in the ground
                          working donor board 4kOhm. Is it a cpu problem?
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            What voltage do you have top side of the R410 is it 1D35V_S3 or 0.125v ? If you don't have 1D35V track it back page 49 VDDQ_VTT for thé moment cannot rule out CPU
                            • limpidity
                              • Sep 2019
                              • 49
                              The r410 resistance is measured, and you get 1 mega ohm
                              I replaced it with 470, but the symptoms remain the same
                              DDR3_DRAMRST# r404 0.125v....
                              Other voltages are normal output
                              Is it cpu memory controller problem?
                              • menshawy
                                Dell Inspiron 15-3542 2beeps porblem
                                by menshawy
                                hi friends
                                i have Dell Inspiron 15-3542 with 2beeps problem
                                mb Wistron Cedar 13269-1
                                i try to change the ram and clean ram slot and reflash bios with ok tested one
                                but with no result
                                pl4902 1.35v
                                dm1 -ram slot volts(with ram)
                                pin 204 vtt1 = .675v
                                pin 199 3.4v
                                pin 30 DDR3_DRAMRST# 0V
                                R410 PIN1 1.35v
                                pin2 0v
                                it is fault cpu ?
                                any help please
                                thanks
                                09-27-2020, 05:56 AM
                              • shahnld
                                Msi gs66 charging issue
                                by shahnld
                                Good Evening Masters..
                                My msi gs66 has a weird issue. It had a shorted mosfet on vram rails and 1x current sense to gpu or vram was melted,. I replaced the mosfet and currenr sense resister and the laptop started to work,
                                but When plugged in it says battery is 99% and as soon as i remove the charger the laptop shutsdown.. beside this issue laptop is fully functional.
                                So i opened it and i checked voltage on battery +. Without charger in MV's, when i plug in the charger then voltage on battery+ connector goes to 19.75v and then starts to drop until MV's. This...
                                01-26-2025, 05:13 PM
                              • bembeno
                                Dell 3542 2 beeps issue
                                by bembeno
                                i have dell 3542 no display and 2 beebs code i measured the ddram rst on resistor R410 one of the sides is 1.35 and the otherside is 0.21 v is it ok ? or i should replace the r410 resistor...
                                08-30-2022, 02:34 PM
                              • ravi_1617
                                LG R410 schematic
                                by ravi_1617
                                Hi! this board has display external fine.
                                But not on LCD .there is a flash on lcd screen.
                                I need schematic
                                01-05-2016, 12:44 AM
                              • hazardus
                                Dell XPS 15Z 2beeps
                                by hazardus
                                I've a Dell XPS 15z with two beeps and no screen issue. I tried a different RAM it didn't help.
                                I replaced the SLJ4P chip with a new one but didn't help. What should I check?
                                Thanks.
                                01-21-2015, 02:23 PM
