MSI GP60 2QF Leopard Pro distorted sound
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Hello.
    Have this msi MS-16GH MSI GP60 2QF Leopard Pro gaming laptop that have weird sound. owner say he using much headphones jack
    check audio attached
    where to start finding fault?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: MSI GP60 2QF Leopard Pro distorted sound
    on headphones sound is good, only on reproductors is bad
      • 21282
      Have you tried it with linux .If its only happening under win 8/10 try to reinstall the Soundblaster cinema,and EQ drivers
      https://forum-en.msi.com/index.php?topic=289686.0
      https://cdn.badcaps-static.com/pdfs/...68dba913c6.pdf
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3610
        • slovakia
        i try it with ububntu and works the same. i think it is in amplifier but need schematic to check that
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3610
          • slovakia
          i check amplifier. i have flicker voltage on input and output, but on ALC892 sound chip output lines is stable
          VDD voltages on both chip is solid and ok
          have u some hint how to check sound before it enters amplifier?
          • KvnTM
            • May 2018
            • 434
            Just play a 1khz square wave on the laptop and connect a scope to input and output. There are many programs that can do this.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3610
              • slovakia
              i check input sound to amplifier with headphones and it is ok.
              Amplifier is APA2031
              BYPASS line have flicker voltage. what does this BYPASS signal?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3610
                • slovakia
                from datasheet i see that bypass is just connected to capacitor, so i will order amplifier ic and replace it
                • LEECH666
                  Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                  by LEECH666
                  Good day ladies and gentleman!
                  I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                  This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                  I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                  01-19-2024, 05:46 PM
                • maleksa
                  Yamaha MOX8 boot freeze and distorted sound
                  by maleksa
                  My Yamaha MOX8 synthesizer recently developed two issues.
                  Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                  Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                  11-07-2024, 03:28 AM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • televizora
                  HP 8470p - distorted sound and noise when playing audio
                  by televizora
                  Hello.
                  I have an issue with HP 8470p - rather strange one.
                  I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
                  Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
                  Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
                  12-31-2021, 10:25 AM
                  MSI Gaming LEOPARD GP66 11UG-690CA Notebook GP Specification for Upgrade or Repair
                  This specification for the MSI Gaming LEOPARD GP66 11UG-690CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LEOPARD GP66 11UG-690CA boardview and LEOPARD GP66 11UG-690CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-07-2024, 06:40 AM
