alienware 17 R4 power on/off, no post
  • reverendalc
    • Jul 2016
    • 81
    hey all,
    i've got an alienware 17 R4 on my hands, LA-D751P BAP10 Rev1.0
    when i received it, this was the behavior:
    press power button= fan spin, led/kb illuminate for a second, then powers off. no LCD/backlight
    <repeat until power is cut>
    if i remove the RAM and power on=
    machine would power on then LED would indicate bad CMOS batt
    if i remove the CMOS batt and ram, i will get NO RAM LED error
    i tried several bios dumps from this forum, which all result in CPU FAILURE LED error. some bios will give me full tron lights, others only LCD/lid tron lights.
    if i write back original BIOS, i get original errors/symptoms.
    have tried disconnecting all RAM/HDD/SSD, various combination of batt/AC power, have tried cleaning ME on all dumps, so on and so forth.
    totally at a loss here, help please!!!
    This isn't Monaco... This is Baghdad
  • reverendalc
    • Jul 2016
    • 81
    Re: alienware 17 R4 power on/off, no post
    followup: if i clean ME on original read, the machine will power on and complete ME initialization, and then start the on/off cycle.
      • 20530
      Post your original bios backup in the bios requests sub-forum .
      • reverendalc
        • Jul 2016
        • 81
        https://www.badcaps.net/forum/showth...503#post917503
        i have uploaded all of my chip reads here. i downloaded a full suite from biosfix however now i cannot write to UG13. it errors out at 12% most often, sometimes 25%, and once at 31%. the chip has been erased. FML
        • reverendalc
          • Jul 2016
          • 81
          Oops. I guess that's a 1.8V chip. Need to get a 1.8v programmer.
          Is the KBC programmer viable in a situation like this?
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
            03-31-2024, 02:12 PM
          • Green Probe
            Alienware m15 R5 Ryzen No Power
            by Green Probe
            Hello, I have an Alienware m15 R5 Ryzen, P109f002, with motherboard GDL56 LA-K453P Rev:1.0, Ryzen 9 5900HX, RTX 3070. I got it due to it having liquid damage. I am quite new to chip-level repair, and this is my second post, so please be kind with my incompetence. The charging IC is an ISL95522ah in HPB mode as far as I'm aware. I've been using a schematic for a LA-K455PR10_0525A that is available in the forum, and it seems to match for the most part. If it's okay I can link the schematic, or insert the pertinent page into my post.
            It had some crusty areas that I've cleaned up....
            02-05-2024, 02:46 PM
