Lenovo Yoga 2 Pro 20266 Stuck in sleep mode
  • GIFixed
    • Sep 2019
    • 61
    • Denmark
    Dear all,
    Thank you for your effort and for the good forum.
    This is my first post. I have searched long time for this problems, but it seems no answer to my specific problem.
    I have this laptop for a customer to check.
    It is like in sleep mode and never gets out of it.
    The power LED and keyboard backlight turns on shortly every about 5 seconds.
    (It is like the video that was in one thread on badcaps forum - I cant find it now)
    Only power off by pressing the power button for about 10 seconds. Pressing power button gets it to this sleep state again.
    Could not find the write schematic and no board view. I have the NM-A74 schematic to get help from.
    Details:
    Lenovo Yoga 2 Pro
    M/N 20266
    Main board:
    Kona_SVT
    EBKN7 V-0
    RIO board: Hannstar NS-A071 Rev 2.0
    LIO board: Hannstar NS-A072 Rev 1.0
    Charging seems OK
    ADAPTER OK
    Without charger - only battery:
    Battery reseated
    - S4/S5 state (DC)
    - VCCRTC ? could not measure. RTC battery present.
    - VIN: 7.2V
    - +3VALW : 3.3V
    Push power button gives:
    S0 State with following voltages:
    VIN: 7.2V
    +3VALW : 3.3V
    +5VAUX: 4.94V
    +3VAUX: 0V
    +1.2VSUS: 0V and momentary 1.2V every 5 seconds
    CPU_CORE: 0V and momentary 1.xV every 5 seconds
    MAINON: 0V and momentary about 2.5-3V every 5 seconds
    If I press power button for about 10 seconds it turns off - ONLY on battery. It does NOT turn OFF if charger is connected.
    When charger is connected it automatically gets “turned ON” but in this “Sleep” state. MAINON trying to turn on every 5 seconds
    CPU does not get warm
    No fan spin at all.
    SMBUS signals shows 3.3V. Does not seem to be shorted.
    When charging, coil PL7 gets hot.
    Help needed. Thanks
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo Yoga 2 Pro 20266 Stuck in sleep mode
    Any history?
    Since it's power cycling up to CPU VCore I'd try to flash the BIOS first.
    • GIFixed
      • Sep 2019
      • 61
      • Denmark
      We dont know what the customer did before it got to this state.
      Do we have the bios for this machine?
      I need to buy rom/BIOS flasher. Which one do you recommend. It has to be used for PCs and Apple, etc.
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        me too experienced these problem but with acer brand laptop. what i did is disable all the sleep and all pertaining to hibernation in power option in battery power option as temporary measure. it work well but of course i want to know the real problem to solve it permanently.
        what i did is update the bios to the latest version it did nothing to the problem.
        replaced with new memory still no avail.
        reformat the whole system with new windows, still when it sleep you need to turn off the system to make it wakeup.
        tweak the cmos bios option still no avail.
        visual check the mobo searching for burnt or ic, mosfet with holes
        check all the power 1.35v memory voltage for ddr3L 5volts, 3.3volts, 19volts, etc
        until i tweak the power option in battery icon disabling all the sleep and hibernation mode. it works!!!, only problem is you don't save battery power. i contacted acer tech support only to find out. it is the nature of that acer model to do that darn thing!
        i want to know the real problem and what to replace or where to check to repair it permanently. ACER tech support give up on me
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I would have replaced LID Switch first.
          • piernov
            • Jan 2016
            • 4439
            • France
            This is a different problem, please don't hijack other people thread. Open you own.
            • GIFixed
              • Sep 2019
              • 61
              • Denmark
              Originally posted by piernov
              Any history?
              I have ordered BIOS flasher TL866 II Plus.
              • GIFixed
                • Sep 2019
                • 61
                • Denmark
                Where is this LID switch located?
                I have no boardview.
                • KvnTM
                  • May 2018
                  • 434
                  I had a few issues regarding the normal Yoga 2 maybe I can help you a little.
                  Have you checked the ram voltage? On my Yoga 2 the ram voltage was missing and it kept bootlooping every 5 or so seconds.
                  I know the Yoga 2 Pro is different but on mine the lid switch was located on the USB/SD Daughterboard connected by a ribbon. Just disconnecting it was disabling the lid switch to an permanent "open" state. But I highly doubt that this is your problem because if the lid is closed it won't react to the power button at all.
                  Could also be very well a bios issue but take a look at ram first.
                  I would suggest a CH341A based flash programmer. They are dirt cheap and work very well.
                  EDIT:
                  I read that it doesn't occur if a charger is present. Likely something else beside bios and ram. Does the laptop turn on/sleep normal with charger?
                  • GIFixed
                    • Sep 2019
                    • 61
                    • Denmark
                    Attached an image from the schematic. I have marked the voltages who are ON with green, and those flickering with red.
                    • KvnTM
                      • May 2018
                      • 434
                      Yeah it is power cycling.
                      Please measure +1.35VSUS.
                      Can be measured at PL9, PJ39 or TPF106
                      • GIFixed
                        • Sep 2019
                        • 61
                        • Denmark
                        @KvnTM
                        The +1.35VSUS is indeed +1.2VSUS/5A on the power diagram (from the schematic). It is misspilled.
                        Beside it I wrote in red (maybe too small) "PJ39".
                        It is recycling like all the others in red.
                        It is hard to finde TPFxxx, or any component designations on board. It is black board. Only Diodes, coils ICs - no discrete components. That is what is doing it very hard to diagnose.
                        All the green power voltages are either direct from VIN or enabled by AUXON.
                        All other red marked voltages are enabled by either SUSON or MAINON.
                        Both SUSON and MAINON are power cycling.
                        +3VAUX is present, but almost all logic are powered from +3V rail, which is power cycling.
                        If I connect all cables and duaghterboards or I separate the main board, I get same result.
                        • GIFixed
                          • Sep 2019
                          • 61
                          • Denmark
                          Maybe Iam wring, but what I understand from the schematic, it is the IT8586 whom is generating the SUSON and MAINON signals?
                          • KvnTM
                            • May 2018
                            • 434
                            @KvnTM
                            OK.
                            Reflash your bios chip.
                            If all power rails are fine and have the expected voltage then it is most likely your bios. You mentioned that you can only shut it down by holding the power button for some seconds while on charger. correct? This is also a symptom of a corrupted/missing bios. Could be something else like a dead cpu but I highly doubt that.
                            MAINON and SUSON are outputs of the EC. It will power cycle the board if it can't read the bios rom or if it is corrupted.
                            Either you have a bad EC or a bad Bios. Everything else should be fine.
                            Off Topic:
                            If you think this is a hard board to work on then you haven't seen a macbook logic board. Matte black pcb with absolutely no silkscreen/designators at all. Also soldering on them is a pain. You will rip a pad just by blowing at it. I always love to have non macbook boards.
                            • KvnTM
                              • May 2018
                              • 434
                              Correct. Dont try to pull them high by injecting voltage or do something else with MAINON and SUSON. Killing your EC (IT8586VG) would be bad news since it is a BGA Chip and would be a pain to replace.
                              I've already had a dead EC but it is really rare from what I experienced. Most of the time the bios flash is just corrupted. Maybe the owner did a bios flash and decided to restart it or flashed a wrong bios? Who knows... Always think of the dumbest thing people could do to it. If it doesn't have water or other physical damage it's most likely some software (bios) related thing.
                              • GIFixed
                                • Sep 2019
                                • 61
                                • Denmark
                                No, it is when only on battery I can turn it off by holding the power button for some seconds.
                                It does not turn off, when charger is connected, regardless of battery.
                                Well, I worked a little bit with macbook boards, but only with a shcematic AND boardview.
                                I will try to get the BIOS dump from this site. But when flashing BIOS from donor board, it does corrupt the windows key, wright?
                                It is my first time to flash a BIOS by hardware.
                                I am new to real diagnosis of laptop boards. I am in a no-pay intership and trying my best to learn this, so I can get a job.
                                Many thanks for your help.
                                By the way, I have read on internet, these yoga laptops (and maybe others) get their BIOS corrupted by windows update.
                                • KvnTM
                                  • May 2018
                                  • 434
                                  Make a backup of your bios first before overwriting it!
                                  And desolder the flash chip. Do not flash it in circuit. This could kill your EC. The board has protection resistors on the SPI data lines but I wouldn't try it since on many EC's the SPI bus runs at a lower voltage than 3.3V. Your programmer probably runs on 3.3V.
                                  It's pretty rare that Windows corrupts your Bios but who knows. Windows usually has no access to write the Bios rom. But many wonderful things can happen. I had an Asus Laptop which killed itself for no reason at all. Reflashed the Bios and it was fixed.
                                  Your Windows key will be gone. That is correct. And you have to clean the ME region of the Bios dump or it will take 10 or 20 Seconds to POST. Be aware of that when you flash it and turn it on. Just let it sit for a Minute if it stays turned on.
                                  If the Lenovo Logo doesn't appear after a Minute max you probably have a wrong Bios dump. But would be great news if it stays on at least.
                                  There is probably some Tutorial here on how to clean the ME region or someone else could probably help you out on that.
                                  There is a really simple path to follow:
                                  Look for water/physical damage
                                  Check all power rails.
                                  Measure resistance on failed power rail. Resistance too low or shorted to gnd? Probably a shorted cap somewhere. Inject the expected Voltage with current limit and look what gets hot. Replace part that gets hot. Repeat.
                                  Resistance on power rail seems ok? Probably a failed buck/boost converter chip or some signal is missing. Look at Datasheet of the part and check every signal it needs to turn on.
                                  All power rails present and turns on with no display and cold CPU? Check Bios
                                  If you can rule out power rails and bios it probably is some chip which can be annoying to pinpoint.
                                  • GIFixed
                                    • Sep 2019
                                    • 61
                                    • Denmark
                                    There is no sign of water nor physical damage.
                                    I have measured all power rails and could not find any short to GND.
                                    I was afraid of injecting power on power rails not to blow the EC, CPU and anything other. At work we have the HP Agilent power supply with current limiting as in attached picture.
                                    • KvnTM
                                      • May 2018
                                      • 434
                                      There is no need to inject voltage into the board at this point since all power rails seem to be ok. Could be some current sensing circuit but I doubt that. Injecting power only makes sense if a power rail is shorted and you can't find the bad component. This is not the case here.
                                      The Yoga is just power cycling. I guess a reflash of the bios will do the trick.
                                      The EC should be fine since it does do something. A dead EC would usually prevent the board from starting at all since the power button is connected to it. Do you have access to an oscilloscope? You could monitor the SPI data lines on the bios chip.
                                      • GIFixed
                                        • Sep 2019
                                        • 61
                                        • Denmark
                                        Unfortunately, we dont have an oscilloscope. But I personally have this logic analyzer, but never used it:
                                        https://www.ebay.com/itm/USB-SALEAE-...a9987303219201
                                        Is it usable?
                                        • ekozeko333
                                          by ekozeko333
                                          🧠 What I’ve Done So Far
                                          Flashed...
                                          06-21-2025, 02:48 AM
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:00 AM
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                          Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
