Lenovo Yoga 2 Pro 20266 Stuck in sleep mode
  • piernov
    • Jan 2016
    • 4439
    • France
    #41
    Re: Lenovo Yoga 2 Pro 20266 Stuck in sleep mode
    Since the behaviour changed with a BIOS flash, it still seems the issue is related to BIOS. It can also most likely exclude any issue related to the power sequence.
    • GIFixed
      • Sep 2019
      • 61
      • Denmark
      #42
      Originally posted by KvnTM
      Actually you are correct again. Shame on me. I looked at a datasheet from another cpu vrm/buck converter/pmic or however you wanna call it. It is an open-drain output which obviously can't output any voltage. I'm still stuck in the 3.3v logic level world. Time to move on I guess.
      Maybe you can have a guess what's wrong with this thing? Everything seems to be ok. The only thing left for me would be the EC Firmware or a dead CPU.
      Something just struck my mind... I had some older laptops before that wouldn't post without the rtc/bios battery.. Can't remember the manufacturer but I believe it was acer. Certainly not Lenovo. OP should take a look at it.
      Sorry to the OP for making false hope though.
      You are good people and friends over here in this forum. I appreciate your help.
      Regarding RTS/BIOS battery, it is the same if battery is connected or not. The cell battery is in good condition.
      I have a question, I flashed your (KvnTM) suggested bios bin file. But Should we clean ME region and try? And how quickly can we do it? I did not do it my self before.
        • 21960
        The bios battery should be 3V,and should be removed when programming or soldering the bios,and put back after .Try a virgin lenovo bios,it has clean ME firmware.
        https://www.badcaps.net/forum/showthread.php?p=918233
        • KvnTM
          • May 2018
          • 434
          Could very well be. It's really confusing since he already tried many BIOS dumps and not much is changing. But the board should be ok IMO. Everything major is pretty much ruled out. It also could be dead ram and would be a pain since it is soldered to the board. But I guess it wouldn't power cycle in that case.
          I always remove the flash ic. I had mixed results flashing it in circuit.
          I always try my best to figure something out but you get on the wrong track real quick on these boards.
          A clean ME region would just speed up POST dramatically. It never occurred to me that the board wouldn't start at all. Only takes around 20 Seconds longer before anything happens. But give it a try with the bin SMDFlea mentioned. Your Board should be fine. All power rails are present and within spec. It just resets itself for whatever reason.
          Little sidenote: Can you toggle the keyboard backlight? (FN + Space on my Yoga)
          • GIFixed
            • Sep 2019
            • 61
            • Denmark
            #45
            1) I desolder the chip before flash.
            2) The virgin flash bin did not power up the board: It power cycles like the original.
            3) When using W25Q64_20161231_45833.BIN:
            - Does not power cycle totally, but amperage "cycles" from 0.550A for few seconds and then down to 0.300 A for a short time.
            - Can toggle keyboard backlight using FN+space.
            - CPU and ram get warm and then fans spins.
            But still no screen and no activity on usb flash stick.
              • 21960
              What is your serial number
              • GIFixed
                • Sep 2019
                • 61
                • Denmark
                #47
                On bottom case: S/N YB01410862
                • KvnTM
                  • May 2018
                  • 434
                  I cleaned the ME Region for you.
                  It is based of the dump W25Q64_20161231_45833.BIN.
                  File is attached. Give it a try
                  Last edited by SMDFlea; 06-23-2021, 07:05 AM. Reason: NOT bios requests/dumps thread
                    • 21960
                    I posted a bios based on that one too,and a virgin bios .https://www.badcaps.net/forum/showthread.php?t=79575 .Only the bios you posted at post #25 makes the laptop boot a bit further,and it doesn`t have a clean ME .Its booting further after reading the ME or some setting in the NVAR.
                      • 21960
                      Try a mild reflow on the RAM,use plenty of flux.
                      • KvnTM
                        • May 2018
                        • 434
                        Yes i know it did not have a clean ME. The one in my last post should. I cleaned it with the Intel ME/TXE Injector using Intels Firmware Repository.
                        But as you mentioned he should reflow the RAM. Maybe that will do.
                        • GIFixed
                          • Sep 2019
                          • 61
                          • Denmark
                          #52
                          Thank you both of you, KvnTM and SMDFlea.
                          I will try your suggestions on monday and post results.
                          • KvnTM
                            • May 2018
                            • 434
                            Any updates ?
                            • GIFixed
                              • Sep 2019
                              • 61
                              • Denmark
                              #54
                              Any updates ?
                              Sorry, no updates yet.
                              My chef should reflow it for me (I am not so trained at reflowing). But he is busy.
                              I will update when it is done.
                              Thanks for all your help and patience.
                              • GIFixed
                                • Sep 2019
                                • 61
                                • Denmark
                                #55
                                Sorry for late update.
                                I have reflowed RAM chips - did not help.
                                I have reflowed CPU - did not help.
                                Now work on this machine is stopped. It will come back to customer urepaired
                                Thanks for all your support and help.
                                • KvnTM
                                  • May 2018
                                  • 434
                                  Thats sad news. Something probably died on that board which is hard to find. Could even be the CPU itself or most likely the PCH.
                                  • Tha_untouchable
                                    • Sep 2023
                                    I know this is an old thread but i think it could be useful for the next one which is/willbe searching for an answer.
                                    The author of this thread mentioned that the board was getting hot 🔥 but he never found the orgin of the defect .... but I think it could be the same defect like mine .... So I was searching with my microscope on the board for burned things and so I can put my multimeter perfekte on the contacts without shorting them as I saw next to the battery plug an IC CHIP which is directly from lenovo when i was about to get to the next thing so i can check it i saw a very strange mark on it i wanted to wipe it away but it was to hard so i used a very thin tweezers which was almost thin like a needle......as i was scraping of the dirt i saw it was a hole ..... so my dann ic is burned away an i can't use this laptop....
                                    So what now? As i searched for the IC i found it but also noticed that has to be programmed the i will be able to use the IC ..... which means for a guy like me it ain't possible to reprogramm it without a proper proammer.....
                                    • Tha_untouchable
                                      • Sep 2023
                                      Here is the picture of that damn thing
                                      • Sephir0th
                                        • Oct 2020
                                        • 1289
                                        This is the embedded controller and normally the board can't reach that far in the power up-sequence with a defective EC. For this reason I would assume another fault in your case.
                                        FairRepair on YouTube
                                        • ekozeko333
                                          by ekozeko333
                                          🧠 What I’ve Done So Far
                                          Flashed...
                                          06-21-2025, 02:48 AM
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:00 AM
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                          Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
