I have a acer one d270 , the problem is if i used bench lap supply the laptop works fine, but when i used a charger laptop cannot turn on.I already tried good chargers and original charger but still same issue. does anyone encounter this please help
acer one d270 problem
Re: acer one d270 problem
ACIN Pin 2 AC Adapter Detection Input. Range zero to 5.5V.
ACOK AC Detect Output. This open drain output is high impedance when ACIN is greater than 3.2V. The ACOK output remains low when the ISL88731C is powered down.Range 3.3V to 5.5V.
Find out if the Fet PQ38 Drain Voltage with the Original Adapter what is the Voltage on same pins with the Bench lab supply
the diferrence on ISL88731C same on pin2 and pin 13 but different on pin22 on original charger 4.9 with bench lab plugged in pin22 is 10v.i already tried 3 original chargerLast edited by String2016; 09-18-2019, 09:23 AM.
Originally posted by Mulong2019 View Post@mcplslg123 thank you very much for the advise, i trace the resistor connected to pin 2 and pin 13 of the charging ic one is bad no ohms value, replaced it now its working fine with original charger , thank youhappy to help you.
