MS-16J61 water damage
  • orientalsniper
    • Apr 2013
    • 459
    Received recently an MSI GL62 6QD, it had water damage in the KBC, so I replaced it and flashed the KBC firmware and BIOS from MSI site.
    PWR_SW is 3.3V and does go down if I press power button.
    RSMRST# is always low (0V), but if I press power button it goes to 3.3V for a while and then go back down.
    A strange thing I noticed is if I connect the battery, I get a blue LED.
    I'm at a loss, I've got 3.3ALW and 5ALW. And BIOS/KBC are both clean flashed. What's my next course of action?
    I attached schematic for MS-16J51, but it's VERY close to the board I'm working on.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: MS-16J61 water damage
    check ON KBC IC pin 37 53 124 108 110 114 117 121 127
    • orientalsniper
      • Apr 2013
      • 459
      37= EC_RST# = 3.3V
      53= LID# = 0V
      108= AC_PRESENT = 0V
      110= AC_OK# = 3.3V
      114= PWR_SW# = 3.3V
      117= PM_PWRBTN# = 0V
      121= PM_SLP_S3# = 0V
      124= VCC_IO2 = 3.3V
      127= PM_SLP_S4# = 0V
      What do EC_RST#, LID#, PM_SLP_S3, PM_SLP_S4 and PM_PWRBTN# do?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        LID# should be 3v. Try removing lid switch from mb/powerbutton board. PM_slp s3/s4 will generate only after power button press and are generated by PCH.
        • orientalsniper
          • Apr 2013
          • 459
          By lid switch do you mean UB2? LID# is not shorted, but I applied 3.3V from my bench power supply and RSMRST# still won't go HIGH.
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Originally posted by orientalsniper
            37= EC_RST# = 3.3V
            53= LID# = 0V
            110= AC_OK# = 3.3V
            114= PWR_SW# = 3.3V
            124= VCC_IO2 = 3.3V
            EC_RST# RESET KBC 3V
            LID# 3V When you close the Screen of the laptop with the help of this Signel the MB will go to sleep mode
            PM_SLP_S3 -WAKE UP Signel from PCH to KBC
            PM_SLP_S4- WAKE UP Signel from PCH to KBC
            PM_PWRBTN# POST POWER Switch KBC inform PCH
            If RTCRST# is low the PCH won't work at all, the board will stay in the S5 state and SLP_S3#/SLP_S4# will not come up.
            • Techtiger
              • Oct 2014
              • 1602
              • france
              AC_PRESENT Is low 0V find out RN9 any short this Voltage is pull up from +3VSUS
              PM_PWRBTN# = 0V is low, Missing BATLOW# will prevent PCH going out from S5
              • orientalsniper
                • Apr 2013
                • 459
                Couldn't find RN9, had to measure R405, but it was not shorted and AC_PRESENT is not shorted either.
                AC_PRESENT and PM_PWRBTN# go HIGH (3.3V) for 12 seconds if I press power button once.
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  Find out any short in RTCVCC RTCRST SRTCRST
                  • orientalsniper
                    • Apr 2013
                    • 459
                    MS-16J61 seems to be different to MS-16J51 in the RTC circuit.
                    But R434 does not appear to have short and it's connected directly to (+) side of CR2032 battery.
                    • mibo012
                      • Feb 2019
                      • 23
                      • Slovakia
                      Thanks orientalsniper
                      • ADABILISIM
                        • Oct 2024
                        • TURKEY
                        Try this ms 16j61 schematic
                        • edugimeno
                          Stagg sms12p audio amp has water damage
                          by edugimeno
                          Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                          I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                          There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                          There is only one signal wire connecting the first boards...
                          05-24-2025, 06:00 AM
                        • Joel Ohana
                          Lenovo IdeaPad 3 15IAU7 that suffered water damage
                          by Joel Ohana
                          I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
                          Symptoms:
                          • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
                          • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
                          What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
                          03-06-2025, 11:25 AM
                        • abajor
                          A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
                          by abajor
                          Like title says A2141 came in with Water Damage, customer desperately wants the data.
                          The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
                          I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
                          That said after cleaning up the...
                          12-21-2024, 07:16 PM
                        • rtstorm
                          HP EliteBook 840 G8 water damage - identify component
                          by rtstorm
                          Hello, i got an HP EliteBook 840 G8 that has water damage, and i found this component has damage on it U60600. What is that component? I have schematics and boardview and the par no is:
                          SINERGY_SYV128RAC_QFN_20P i cannot fount it anywhere. Is this component have some other name?
                          Here is schematics + boardview...
                          09-18-2024, 05:36 PM
                        • TimSinger
                          MacBook Pro M4 16" A3403 on the table with water damage
                          by TimSinger
                          Hi guys,
                          I have a MacBook Pro M4 16" A3403 on the table with water damage. I allready found the problem within a bad cap. As far as my researh went, I couldn't find the schematics and boardview for this MacBook model. They seem not to be released now. So my question is if anybody has a working A3403 on the table and could tell me, which specification this capasator has?
                          I attached a photo of the missing cap. It's on the bottom side of the logicbard.
                          I am very thankful for your replys.
                          Thanks in advanced and best regards from Hamburg Germany...
                          07-13-2025, 11:12 AM
