immediately turn off acer e5-574g
  • khelane
    • Apr 2015
    • 168
    • xxxx
    hi
    Acer e5-574G
    DA0ZRWMB6G0 rev: G
    this device in while watching movie hanged and force shutdown by user .
    client told me 2 or 3 time device hang and him forced shutdown .
    now this device turn on but immediately turn off . led power turn on and off for second .
    no burnt ic and component .
    3.3 and 5 and 19 is present.
    coil cheked ohm .
    please help me .
    tnx
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: immediately turn off acer e5-574g
    Backup old Bios Dump and Flash Bios with a new one
    • khelane
      • Apr 2015
      • 168
      • xxxx
      tnx
      but i have not it bios
      please if you have bios upload it
      • Techtiger
        • Oct 2014
        • 1602
        • france
        https://www.badcaps.net/forum/showth...RWMB6G0+rev%3A
        • khelane
          • Apr 2015
          • 168
          • xxxx
          programmed 2 or 3 time and changed ic bios and not working .
          turn led and fan for 1 or 2 second and shutdown .
          I/O is programmable IT8987e .
          • Techtiger
            • Oct 2014
            • 1602
            • france
            find out the Schematic of the MB find out +3VPCU +5VPCU getting transfer to +3V & +5V and what Voltages are missing when power up test the Voltage on all big Gray Coils
            • khelane
              • Apr 2015
              • 168
              • xxxx
              6 big coil no voltage before start and after start !
              no heat IC's or component
              • Techtiger
                • Oct 2014
                • 1602
                • france
                page 31 PL6013 PL6012 is your 3V & 5V Coils test the Voltage , PU6010 test the Voltage pin 3 12 13
                • khelane
                  • Apr 2015
                  • 168
                  • xxxx
                  yes voltage are present 3.3 and 5 v on coil
                  pu6010
                  pin 3 3.3v
                  ping 12 19.5 v
                  pin 13 5 v
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    now find out PQ308 PQ18 pin 123 voltage as you press the power button after find out the Voltage on U45 SIO pin 112 107 3 84 123 33 72 100
                    • khelane
                      • Apr 2015
                      • 168
                      • xxxx
                      pq308 not found in schematic
                      pq18 pin 123 is 3v
                      pins SIO
                      112 3.3V
                      107 3.3V
                      3 3.3V
                      84 3.3V
                      123 3.3V
                      33 3.3V
                      72 2.9V checked ohm to GND 84k
                      100 3.3V
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        SIO pin 112 RSMRST check as you press the power button if this voltage go to 0V and come back to 3.3V , out put of PQ38 pin 123 ?
                        • khelane
                          • Apr 2015
                          • 168
                          • xxxx
                          hi
                          pin 112 before switch on 0 v and when i press power button pin 112 go to 3.3 and active 3.3v on pin112 until laptop shutdown and pin 112 go to 0v ?!!
                          3 or 4 time checked it pin!
                          PQ38 : 5V on 123pin
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            Pin DNBSWON SIO 123 14 119 18 check as you press the power button (#) THIS INDCATE HIGH/LOW , find PU12 IC pin 7 & 3 PL11 as you press the power , go through page 44 power diagram to see what voltage is missing ,This cause may be shorting or Voltage not getting the place where it need or BIOS
                            • khelane
                              • Apr 2015
                              • 168
                              • xxxx
                              123 is 3.3
                              14 is 3.3
                              119 and 18 not voltage and when i put probe on pins 119 or 18 device can't turn on but remove probe on pins and switch device go on .!!
                              pu 12 are 1v_s5 and no problem
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                it seem to be PCH is not out putting S4/S3 SMD component shot between may be , what is the resistance to GND on those 2 pins SUSB SUSC S4/S3 pin 119 & 18
                                • khelane
                                  • Apr 2015
                                  • 168
                                  • xxxx
                                  pin 119 87k ohm
                                  pin 18 77k ohm
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    Check U48 pin 2 SUSC U49 pin2 SUSB if the signal comes in
                                    • khelane
                                      • Apr 2015
                                      • 168
                                      • xxxx
                                      I haven't Oscilloscope
                                      • Techtiger
                                        • Oct 2014
                                        • 1602
                                        • france
                                        Check the Voltage on those pins U48/49
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
