COMPATIBLE BIOS CHIP for PCT25VF032B-80-4I-S2AF
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Everytime I am trying to flash the BIOS chip , I keep getting this verification error.
    MB Part Number : 6-71-w24e0-d03 gp
    MAIN BIOS PART NO : PCT 25VF032B-80-4I-S2AF
    Also wondering if any schematic is available for this
    this Motherbaord ?
    Model Name is : HCL ICON L1065
    Thanks in advance.
    • 21472
    Re: COMPATIBLE BIOS CHIP for PCT25VF032B-80-4I-S2AF
    I don`t know if you`ve noticed but there`s a schematic requests sub forum .
      • 21472
      Model number of programmer ? ,it might have a known problem with some brands of bios chip, make sure your software is the latest .
      • IamPritesh
        • Aug 2017
        • 356
        • India
        I am aware of the schematic sub forum.. I will post another post in the correct forum
        its RT809F PROGRAMMER
          • 21472
          The 25VF032B is supported. Most likely the chip is bad.
          • Francisco.s
            • 686
            • Spain
            Can you read or erase this chip?
            • IamPritesh
              • Aug 2017
              • 356
              • India
              I can erase the chip bt after reading or writing the verfication always fails.
              • IamPritesh
                • Aug 2017
                • 356
                • India
                Anyone know alternative to 25VF032B ?
                • Francisco.s
                  • 686
                  • Spain
                  My programmer doesn't show any special feature of 25VF032B.
                  Try the "generic" 25q32fv.
                  • IamPritesh
                    • Aug 2017
                    • 356
                    • India
                    Tried with another winbod 25VF032Bit throws the same error@verification fail. Write aborted.
                    I can flash other bios ..like one of dell 3521 . I dont know why it causing issue with this particular chip model.
                    Anyone every faced anything similar ?
                    • JoWed
                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                      by JoWed
                      Hello Community,
                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                      07-01-2025, 09:32 AM
                    • thxd43
                      Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                      by thxd43
                      Hello, first of all, excuse me, I am using the translator, English is not my native language.
                      I have a Lenovo ideapad 330S - 14IKB laptop.
                      The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                      02-23-2023, 08:37 PM
                    • hotcrossedbuns999
                      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                      by hotcrossedbuns999
                      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                      3. I could only locate two chips that look like bios chips. Could someone verify this
                      01-03-2025, 12:32 PM
                    • Azurain
                      Elitebook 840 G5 Bios Chip Soldering Question
                      by Azurain
                      I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                      Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                      04-14-2023, 06:58 PM
                    • ed1i
                      Dell Inspion 7610 bios chip
                      by ed1i
                      Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
                      01-16-2025, 02:14 PM
