Cq 42 135-tu( da0ax3mb6c0 rev:c) Uma conversation
  • karimreza2
    • Mar 2018
    • 23
    • Bangladesh
    My laptop ampere 0.900 but no display. PLTRST also ok. NB & SB board. If i plug in ram ampere no change ampere same. Help me
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Cq 42 135-tu( da0ax3mb6c0 rev:c) Uma conversation
    Is this core2duo mb?? I'll suggest to flash bios if not done yet. Ram used is DDR2 or DDR3??
    • karimreza2
      • Mar 2018
      • 23
      • Bangladesh
      sir can u give me a bios file .i have try many time but at the present time its not turn on (not switching)
      • String2016
        • Nov 2015
        • 2238
        • philippines
        try this for ddr3 reply and confirm if its working
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Why should i post a bios file for you when you dont bother to reply whether your mb is ddr2 or ddr3?? You didnt post any measurements either. With such poor description of your problem, why should i waste my time helping you?? You didnt mentioned how the mb went dead as earlier it was switching. Remember, mb is in your hand and if you dont describe symptoms in detail, its not possible to give correct advise.
          • playit
            diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
            by playit
            hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
            and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
            for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
            02-26-2025, 05:39 AM
          • misha97123
            ASUS FX504GM DABKLIMBAB0 revC prob with EC or chargerIC
            by misha97123
            Hi, such a problem, the laptop after an unsuccessful firmware update, the dump was dirty, I flashed the dump (from the offsite), the laptop turns on and the battery charges everything seems OK, but if the power supply and battery are connected at once, then the touchpad freezes and the OS loads long time, but if you work only from the battery or only from the power supply then everything is fine and fast, and there is also a problem that when you disconnect rtc and turn off all power, the asus boards should have an auto turn on, but it does not... also, if you turn on the laptop from the button...
            08-09-2023, 04:00 AM
          • Burnedoutplacebo
            Ampere PEX adn 1.8 v rails resistance value
            by Burnedoutplacebo
            Working on a Zotac RTX 3070 with: PEX at 1v and 6.3 ohm., the 1.8v rail is at 5 ohms. mem is at 1.3v and 42 ohms and the Vcore is 0.7 ohms ( about 0.4 ohms above my background reading) at 0.75 v.
            Question, are the PEX and 1.8v rails resistance too low? Have no video so trying to decide if dead core or something fixable. Dont have oscilloscope so playing with possible bios problem too.
            Advice on resistance values for pex and 1.8v rails appreciated.
            03-19-2023, 04:49 PM
          • teto8485
            hp pavilion 15-ec2043ne mb dag3himb8c0 revc
            by teto8485
            this bios can not setup win 10 or 11 need help to repair this bios...
            02-05-2023, 07:32 PM
          • TraJikar Mac
            [HELP] G712LWS BIOS capsule
            by TraJikar Mac
            I need someone that can capsulate one of the bios files below, and i prefer the older bios version so i can flash it using CH341A tool into the bios chip.
            The manufacturer BIOS files are bigger than the BIOSbackup1.bin files by 256KB and I don't know how to fix or recompile it.
            You can see in this link a conversation between me and other people (Starting at page 10) who tried to help me (thanks to their efforts), but i still couldn't fix it and the laptop is considered as dead until now.
            Also, I uploaded a backup file for the bios that I extracted by using CH341A...
            06-11-2025, 01:35 PM
