Ampere PEX adn 1.8 v rails resistance value
  • Burnedoutplacebo
    • Jan 2023
    • 19
    Working on a Zotac RTX 3070 with: PEX at 1v and 6.3 ohm., the 1.8v rail is at 5 ohms. mem is at 1.3v and 42 ohms and the Vcore is 0.7 ohms ( about 0.4 ohms above my background reading) at 0.75 v.
    Question, are the PEX and 1.8v rails resistance too low? Have no video so trying to decide if dead core or something fixable. Dont have oscilloscope so playing with possible bios problem too.
    Advice on resistance values for pex and 1.8v rails appreciated.
  • Burnedoutplacebo
    • Jan 2023
    • 19
    Re: Ampere PEX adn 1.8 v rails resistance value
    Read resistance values from a working rtx 3070
    1.8v = 2k ohm
    5v = 4.9 k ohm
    pex = 11 ohm
    I think the PEX is okay but my project 3070 has a short on the 1.8v rail as it reads 5 ohms and a second short on the 5v rail where it reads 120 ohms.
    Most likely i have a dead core causing the low 1.8v rail reading, not sure about the low 5 v rail reading but will continue to poke around on both rails to try to ID my short locations and verify if dead core.
    • terror_alpha
      • Mar 2023
      from my experience, a low resistance 1.8v line while everything is fine means the core is dead. i don't think i've ever seen a card like that brought back. i binge watched a lot of GPU repair videos before started working on them myself.
      i got a couple of dead gigajunk 3080ti here. all have the same problem. everything checks out except the 1.8V line. these are all parts cards now. all died recently
      • Burnedoutplacebo
        • Jan 2023
        • 19
        Thanks for the insight. Yep dead core. 1.8v. Short went away when removed the core. Was hoping was a bad solder pad but checked the pads on the core itself that connect to the 1.8v. Line and found 1 at the 6 ohm level. Only one but it was the cause.
        • cind12
          GTX 1080 TI Gigabyte Aorus low resistance on vmem
          by cind12
          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
          Resistance on 12V 4K ohms (Power present when on)
          Resistance on 12V PEX 4K ohms...
          12-08-2023, 09:09 AM
        • Cemal Odabasioglu
          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
          by Cemal Odabasioglu
          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
          Observations...
          01-14-2025, 03:54 PM
        • ResoluteHawk
          Lenovo Legion S7 15ACH6 Not Posting
          by ResoluteHawk
          I have a customer that brought in a Lenovo Legion S7 15ACH6. The problem is that the laptop is not posting.
          My first thought was to take out the DRAM and put it back in.
          No POST.
          Then I swapped the dedicated RAM with good known working RAM.
          No change.
          I then measured to see if 1.2V was being generated for the memory to turn on, so I measured PL600 which is where the output of the 1.2V rail is.
          Resistance was good; measuring ~40Ohms with the slotted RAM in.
          I took the slotted memory out and measured again.
          Resistance with...
          12-02-2024, 10:17 AM
        • Jane
          Resistance of rails in laptops
          by Jane
          Are there general guidelines that tell what resistance each voltage rail in laptop should have?
          02-25-2023, 09:35 AM
        • agent0bean
          Acer Aspire a715 - no power, 10ohm resistor keeps blowing on VCC
          by agent0bean
          I got Acer Aspire A715-42G, no 19v going through the DC-IN mosfet. I also checked the components/power rails downstream and no short detected (gpu and cpu rails are at 2-10 ohms)
          I have checked that there's no gate voltage on the DC-IN mosfet, so I checked if PUB1 has power.
          Turns out there's no 19v going into PUB1 VCC caused by a burnt 10 ohm resistor (PRB12 - 19v stops here).
          Replaced the part but it burned when I plugged in the charger - telling me there's something pulling high current.
          I checked the resistance of PCB16 and it was fine.
          I measured the resistance...
          09-20-2024, 02:18 AM
