asus eee pc 1000h backlight issue
  • mpikou
    • Jun 2013
    • 58
    • Greece
    Greetings,
    Any known issues with low backlight on screen with this netbook?
    Eee PC 1000H
    Thanks in advance.
  • dj_ricoh
    • 2073
    • uk
    Re: asus eee pc 1000h
    How??? i had only one notebook like that still don`t know whats wrong with it but i told the guy take the battery out and let if for an hour and its starting after
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      Originally posted by mpikou
      Greetings,
      Eee PC 1000H
      Thanks in advance.
      try using another lcd panels cfl without removing the bulb, just to to know if bulb is faulty. you dont have to attach the lvds cable.
      • fddizon
        • Sep 2011
        • 555
        • Philippines
        just cleaned the mobo and reseatead connectors, cleaned and lubricate fan.
        after that, mobo turns on.
        • mpikou
          • Jun 2013
          • 58
          • Greece
          Its is not the bulb
          I have connected a brand new Grade A screen.
          I got some broken ones with exactly the same model as the default for test too. Nothing there either.
          I am having some bad time reading the schematics....
          Thanks i advance my friend.
          • dj_ricoh
            • 2073
            • uk
            page 22
            BL_EN = 3.3v Pin5
            LEDIN = 5v Pin 18,19
            LBKLT_CTRL = power control Pin 17
            • mpikou
              • Jun 2013
              • 58
              • Greece
              page 21
              BL_EN = 3.3v Pin5
              Thanks a lot for your reply.
              Did you actually mean page 22 ?
              I was looking at exactly the same section but I am having some hard time finding this on the motherboard...
              Would some photos be helpful to you in order to guide me?
              Thanks again for your reply.
              • dj_ricoh
                • 2073
                • uk
                yes sry.
                its the connector (lvds cable)
                Beware with probes you need to be extra careful not to slip or short(done that)
                • mpikou
                  • Jun 2013
                  • 58
                  • Greece
                  yes sry.
                  I guess you mean that the problem is either on the screen cable or on the connector, am I right?
                  I was hoping for more like a fuse on the motherboard.
                  • dj_ricoh
                    • 2073
                    • uk
                    unplug the cable and check the connector for V , you said that you clean the motherboard.
                    maybe something faulty and you need to find it or you need to supply some direct voltage direct to the connector to start the lamp inside the screen
                    • mpikou
                      • Jun 2013
                      • 58
                      • Greece
                      To be honest I did not mention any cleaning.
                      Some other guy did mention that
                      I am just have an Eee PC with no backlight which I am still trying to figure it out. I am focusing on finding some fuse since the problem is not the screen. By the way, the screen is LED, not LCD.
                      • dj_ricoh
                        • 2073
                        • uk
                        if led then the supply its on the board and you need to trace it down or find another V to give to the led display.
                        you will have to connect it directly if you have many faultys.
                        • mpikou
                          • Jun 2013
                          • 58
                          • Greece
                          This is the reason I am searching for some faulty fuse instead, like I mentioned above.
                          I have repaired a lot of LED motherboards with the same issue but I cannot find the proper part to repair/replace on this motherboard
                          • dj_ricoh
                            • 2073
                            • uk
                            take the dmm and measure the lcd connector from the motherboard and putt here the values
                            • Cornito
                              Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                              by Cornito
                              Hello Team,
                              I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                              Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                              Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                              08-08-2024, 08:09 AM
                            • cheebster
                              iPad Pro 12.9 5th Gen Backlight Issue
                              by cheebster
                              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                              Anyone...
                              05-20-2025, 09:17 AM
                            • MaineFix
                              Asus FX505G LCD Backlight Issue
                              by MaineFix
                              Hello Everyone,
                              Today I'm coming to you regarding my issue which is no Backlight .
                              I have image on my screen but no light.
                              The Laptop was one that came into my shop. Originally it came into the shop with an HDMI port issue. We replaced the mobo and now have a backlight issue. I took off the LCD display and removed the ribbon cable and peeled back the adhesive covering over the board that is connected to the LCD to identify any issues. I took tweezers and wiggled every connection. Everything appears to be fine.
                              Looking for advice....
                              04-25-2023, 12:58 PM
                              ASUS ROG G532LWS-HF074T Netbook Strix SCAR 15 Specification for Upgrade or Repair
                              This specification for the ASUS ROG G532LWS-HF074T Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G532LWS-HF074T boardview and G532LWS-HF074T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 11:20 PM
                              ASUS ZenBook UX325JA-EG125T Netbook 13 Specification for Upgrade or Repair
                              This specification for the ASUS ZenBook UX325JA-EG125T Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX325JA-EG125T boardview and UX325JA-EG125T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 05:30 PM
