Cant turn on hp 15 da0r62mb6e1 rev e board
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    I have a hp board 19V present charger led present. Presing the power button 5v and 3v is present Fan will spin then stop then spin and stop over and over .
    I never tried to flash the bios maybe there is something off about this board
    Please I need some suggestion for this problem
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Cant turn on hp 15 da0r62mb6e1 rev e board
    In the brief interval when fan is spinning, voltages on all coils??
    • Luaina
      • Sep 2016
      • 12
      • Madagascar
      Start first by reflashing the BIOS. It's high likely to be the bios with the symptoms that you highlighted. Make sure to remove first the BIOS battery.
      • kalilinux25
        • Mar 2018
        • 2093
        • ZAMBOANGA SIBUGAY
        i TRIED flashing its bios same rpoblem sir fan sipin then stops and spin then stops
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          Yes all voltages is on
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            its very difficult to find fault in such case as powers on for very few seconds. I'd suggest to replace the 3V regulator IC PU9 or a reflow of the whole mb.
            • kalilinux25
              • Mar 2018
              • 2093
              • ZAMBOANGA SIBUGAY
              Ok sir I ll try it sir
              • kalilinux25
                • Mar 2018
                • 2093
                • ZAMBOANGA SIBUGAY
                I Tried test the vcore is missing sir
                • Duranitron
                  • Jul 2014
                  • 544
                  • Philippines
                  try first the basics, visual check for burned parts, tear it down to the bare motherboard check the powersupply substitute a known working memory connect it first to an external monitor. reflowing will kill your your motherboard unless you have the proper tool for that its a drastic move of course if you really know what your doing. check all voltages, check for short fets (ground one of you ohmmeter prods and poke the positive prods to the coils.) probably a short fets or control ic. kaya mo yan tol.
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    Well first that is somewhat confusing… If VCore is missing, not all voltages are present, and obviously it's not gonna work.
                    So you have to trace back why that is. First checkpoint is ALL_SYS_PWRGD.
                    • kalilinux25
                      • Mar 2018
                      • 2093
                      • ZAMBOANGA SIBUGAY
                      ThanK yOU SIR , possible ba na masira ang processor ng hp sir?
                      • Luaina
                        • Sep 2016
                        • 12
                        • Madagascar
                        Yes you have to check if the enable signal is coming to CPU Regulator ( VRON). Then check the impedance of the VCCore by probing its coil supply. If it is above 3 ohm.Replace the CPU regulator
                        • Duranitron
                          • Jul 2014
                          • 544
                          • Philippines
                          yah i have experience a shorted proccessor. shorted as in 0 ohm resistance but if you can see low resistance in the processor circuit its normal because it is only powered by 1.2 volts or 1 volt mine is powedered by .8 volt so 2 ohms or 3 ohms resistance is not considered shorted an indication of a shorted processor is the frequent shorted mosfet in the processor area.
                          • Duranitron
                            • Jul 2014
                            • 544
                            • Philippines
                            i have experienced this symptoms when i repaired a hp motherboard with a busted control ic and shorted mosfet that powers the memory module. i done the repair replacing all the busted parts and the symptoms is just like the one you have been experiencing. my fault is that i never replaced the original memory module. so replacing it solved the problem
                            • kalilinux25
                              • Mar 2018
                              • 2093
                              • ZAMBOANGA SIBUGAY
                              what type of memory module sir?
                              • Duranitron
                                • Jul 2014
                                • 544
                                • Philippines
                                the low voltage type.. 1.3 volts 4 GB DDR3L
                                • kalilinux25
                                  • Mar 2018
                                  • 2093
                                  • ZAMBOANGA SIBUGAY
                                  I tried but not working
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Did you checked voltages on Ram IC. If you dont feel comfortable in measuring pins for Ram IC, then try replacing it. Does the board remains ON without ram??
                                    • Duranitron
                                      • Jul 2014
                                      • 544
                                      • Philippines
                                      did you repair your laptop. or did you return it to the costumer? have you acquired the schematics? suko na ba tol?
                                      • howardc64
                                        by howardc64
                                        07-24-2025, 05:17 PM
                                      • brzostos
                                        HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
                                        by brzostos
                                        Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
                                        After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
                                        Original HP 150W power supply, the diode in the power socket lights...
                                        10-01-2024, 01:34 AM
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
                                      • air_chair256
                                        Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
                                        by air_chair256
                                        I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
                                        Tried to reball RAM 1,2,3,4
                                        Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
                                        02-13-2024, 06:00 AM
